Ported Intakes, Throttle Bodies, HMS Spark Plug Wire Set, Silicone Couplers/Hose Kits
Old 08-15-2013, 04:10 PM
peakspeedshop's Avatar
Default Ported Intakes, Throttle Bodies, HMS Spark Plug Wire Set, Silicone Couplers/Hose Kits
Be up and running with a ported manifold and throttle body the same day! No more waiting 2 weeks with your vehicle down while getting your parts ported!
Peak Speed Shop has ported LS2, LS3, L76 and LS7 manifolds and throttle bodies in stock. Simply pay a refundable core charge until we receive your removed parts back.
Factory LS2 runner not ported (at top). Runner precision ported by Peak Speed Shop (above)
Plenum with Basic Porting (at top). Plenum with Radical Porting (above -- all center posts removed)
Porting prices start at just $250 for Basic Porting and only $75 more to have your Throttle Body ported at the same time!
Refundable core charges are additional if you want us to ship one to you right away out of our stock.
TO ORDER, go to http://www.peakspeedshop.com/
Listen to what these customers have to say about the quality of our porting work....
"The car picks up so much nicer now, with the top end pulling harder then ever. I always felt that I would get a instant tq rush pressing the gas, and then the power kind of fell off a little. Now I get the same tq rush, and once I hit around 4500rpm, the car just wakes up! Big difference! Thank you again Bob for such a great job! I'm glad I had my manifold ported keeping my stock look! I would do it again in a heart beat!"
Kennan - GA (LS2 Intake Manifold Radical Porting)
"Both pieces came back looking great - just as advertised. The set up runs great and I can feel a difference in throttle response. I haven't really jumped on it yet as the weather up here has been lousy and I'm still on last years gas."
Ken - WA (LS3 Intake Manifold Radical Porting & Throttle Body ported)
“Just had mine done (radical porting) and the work was very good. I've got long tubes, ported throttle body and a CAI and will be getting tuned this week. Bump for a quality service.”
Mike - MO (LS7 Intake Manifold Radically ported)
Old 08-30-2013, 12:56 PM
Default Intake Manifold Removal Step by Step
Here is a link that gives step by step instructions for removing your intake manifold. Most weekend mechanics can do it in about two hours.
http://www.peakspeedshop.com/removal.xhtml
Old 09-18-2013, 02:02 PM
Default Check out our Online Store!
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
Old 10-09-2013, 10:06 PM
to the top
Old 10-24-2013, 10:34 AM
Default Peak Speed Shop porting process
Peak Speed Shop Porting Process
Some have asked about our porting process. Peak Speed Shop uses a three step process for porting intake manifolds and throttle bodies.
First, we use a steel crosscut bur for removing most of the material in key areas and to smooth transitions and ridges for better air flow.
Second, we us sanding rolls for smoothing out the area that had material removed by the crosscut bur.
Last, we using buffing pads to polish the work.
Unlike some businesses that do porting on the side, porting intake manifolds and throttle bodies is our primary business. We have earned a good reputation for quality work and service at competitive prices.
Go to our website at http://www.peakspeedshop.com/ for more information, or call us at 719-651-1952.
Old 11-14-2013, 12:50 PM
To the top
Old 11-25-2013, 06:40 PM
Default Peak Speed Shop now selling Twin Turbo Kits!
Great addition to your Peak Speed Shop ported intake and throttle body!!!
Complete UPP Twin Turbo Kit for C5/C6 Corvettes plus GenIV GTO's and G8's.
STARTING AT JUST $5,850!!!
For more info, go to our thread:
https://ls1tech.com/forums/sponsor-s...urbo-kits.html
Old 12-09-2013, 05:03 PM
Default Peak Speed Shop Gift Certificates for Christmas!
Put a Peak Speed Shop Gift Certificate on your Christmas list!
Apply it towards porting your intake or throttle body. Or, apply it towards any of the products sold at our store:
  • FAST manifolds
  • FAST and Nick Williams throttle bodies
  • Cold Air Intakes
  • Billet style fuel rails
  • Fuel Injectors
  • Torrent fuel lines
  • SLP and Lingenfelter Mass Air Flow sensors
  • Twin Turbo Kits
  • and more!
To order gift certificates, go to http://peakspeedshop.com/Zen_Cart/in...products_id=47
Old 01-08-2014, 01:54 PM
Default Radical 102 intake manifold for GenIV 6.2L Trucks!
Coming Soon From Peak Speed Shop!
102mm Radical Ported Intake Manifold for L92 owners
We have had repeated requests asking when the FAST 102 LSXrt truck intake manifold would be available for the newer GM trucks with rectangular ported heads. We haven't heard of any plans for FAST to put this into production. This has prompted us at Peak Speed Shop to create our own....
Porting intake manifolds and throttle bodies is Peak Speed Shop's primary business. We have perfected a method for completely opening up the plenum "tunnel" and removing additional barriers that restrict air flow in the 6.2L truck manifolds. This is in addition to porting the intake runners for better airflow. For the Radical 102, we also enlarge the throttle body opening on the intake manifold to accommodate a larger 102mm throttle body. We sell the Nick Williams 102mm drive by wire and FAST 102mm drive by cable throttle bodies for this application.
We will be ready to take orders very soon. You will be able to order from our inventory or can send your intake manifold in for conversion. Details coming soon!
Applications (6.2L L92 and L9H):
2007+ Cadillac Escalade
2009+ Chevrolet Tahoe
2007+ GMC Yukon Denali/Denali XL
2007+ GMC Sierra Denali
2008+ Hummer H2
2009+ Chevrolet Silverado 1500 Vortec Max
2009+ GMC Sierra 1500 Vortec Max
Old 01-12-2014, 08:31 PM
42273's Avatar
sent you a pm.
Old 02-14-2014, 12:32 PM
Default Now Available... RADICAL 102!
Order your RADICAL 102 intake, now!
The best way to get your L92 to breathe!
(LS3 intake shown)
Packages start as low as $495!
Packages also available with Drive by Wire and Drive by Cable Nick Williams 102mm throttle bodies.
Order at our online store at: http://peakspeedshop.com/Zen_Cart/in...ath=65_127_129
Or, call us at 719-651-1952.
Old 02-14-2014, 12:37 PM
Radical 102 packages also available for LS2, LS3 and LS7 cars!
Go to:
http://peakspeedshop.com/Zen_Cart/in...Path=65_68_130
Old 02-27-2014, 12:48 PM
Default Radical 102 gains 23 RWHP!
Just got this great note from a RADICAL 102 customer!
“The new addition is great. I didn’t realize how choked up the motor was until the upgrade. I've gotten horse power gains of 23 with the porting and the new 102 throttle body. Although programming is very tedious and sensitive I would still highly recommend anyone with 550+ horse power to have you guys handle the porting. Thanks for all your help.”
Scott - Ponchapoula, LA – Radical 102, LS3
Order at: http://peakspeedshop.com/Zen_Cart/in...Path=65_68_130
Old 03-14-2014, 02:20 PM
to the top
Old 04-18-2014, 02:23 PM
Default Radical 102 LS7
Have a Radical 102 ported LS7 intake all ready to ship. Customer backed out. Call if you're interested in a little price break on this setup (with or without core exchange). 719-651-1952.
Old 04-24-2014, 05:10 PM
Originally Posted by peakspeedshop
have a radical 102 ported ls7 intake all ready to ship. Customer backed out. Call if you're interested in a little price break on this setup (with or without core exchange). 719-651-1952.
item sold
Old 06-02-2014, 12:24 PM
Bump to top
Old 09-04-2014, 10:54 PM
to the top
Old 10-30-2014, 03:06 PM
Bump to top
Old 10-30-2014, 03:25 PM
BURNOUTBOX.NET's Avatar
Now what do you get out of porting the TB and intake?
Quick Reply: Ported Intakes, Throttle Bodies, HMS Spark Plug Wire Set, Silicone Couplers/Hose Kits
