Stage 1 5.7L Heads!
Suspended Sponsor Account
For the month of Oct we will have our Stage 1 5.7L heads on sale. These heads include the following
Fully CNC ported
Hand Finished
Polished Combustion Chambers
Bronze Guides
Larger Hardened Valve Seats
Custom 2.02 Intake Valves
Custom 1.57 Exhaust Valves
Patriot Dual LS1 Springs(Gold Series)
Titanium Retainers
Hardened Spring Seats
Super 7 Valve Locks
Viton Valve Seals
Custom Valve Job
Milled to desired compression
Flowed with sheet
Fully Assembled
Price $1295.00(includeds GM bolts and Gaskets) plus shipping
no core required
Heads are outsourced for the CNC'ing and then hand finished in house and all heads are flow bench tested in house using our SF600.
We have lots of options available and can provide you with 5.3L/5.7L/6.0L heads in either Stage 1, 2 or 3 configurations.
Typical Stage 1 head specs are
Intake runners 223cc's
Exhaust runners 83cc's
Flow Data
lift intake exhaust (w/pipe)
.100 69.7 67.3
.200 142.6 109.9
.300 200.6 141.1
.400 242.4 169.1
.500 271.5 189.4
.600 294.7 205.7
Our Stage 1 heads are designed with the street/strip guys in mind, check the size of the port volume, these heads will produce usable low end torque and also perform well at the track on the top end.
Heads have a 30 days from delivery satisfaction guarantee, if not completely happy will refund your money or resolve your issue.
Heads have a 1 year warranty from defects in material or workmanship to the original purchaser.
We are also AFR dealers, so if in need of some AFR heads give us a shout!
Fully CNC ported
Hand Finished
Bronze Guides
Titanium Retainers
Super 7 Valve Locks
Viton Valve Seals
Custom Valve Job
Flowed with sheet
Fully Assembled
no core required
Flow Data
.100 69.7 67.3
.200 142.6 109.9
.300 200.6 141.1
.400 242.4 169.1
.500 271.5 189.4
.600 294.7 205.7
YYZ28 a member here and owner of torquecentral.com made 393rwhp and 385 rwtq with stage 1 heads and a LPE GT2-3 cam(207/220 .573/.580 117.5LSA) through a 3500 stall. runs the 1/8 in 7.46@93mph
PongoX11 made 531rwhp and 477rwtq with Stage 2 6.0L heads a 224/227 cam and 8psi of boost, stock bottom end. not sure about times at the track
JRP will have some independent results soon
If you decide to give us the oppourtunity to work with you I guarantee you won't be anything but pleased with the results
SN95 Director
here are pics of my heads. my independent flow numbers should be in by the end of the week and my whole combo within a few weeks after that
. also the FFHP has some of the best customer service you will run across, when they say they are willing to help you and work with you its no bullhshit.
exhuast
http://ourworld.cs.com/jrp98ls1/heads/DSC00376.JPG
intake
http://ourworld.cs.com/jrp98ls1/heads/DSC00384.JPG
chamber
http://ourworld.cs.com/jrp98ls1/heads/DSC00381.JPG
bowl area
http://ourworld.cs.com/jrp98ls1/heads/DSC00363.JPG
http://ourworld.cs.com/jrp98ls1/heads/DSC00366.JPG
http://ourworld.cs.com/jrp98ls1/heads/DSC00368.JPG
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
exhuast
intake
chamber
bowl area
Originally Posted by WAHUSKER
Brad,
How much are your Stage 2 5.7L heads? Which would you recommend for my setup?
Mark
Mark
The stage 2 heads we can do for $1395.00 plus shipping(no core,includes GM bolts and gaskets) during the Oct. sale. Stage 2 heads will give you room to go bigger on the cam later on down the line.
on a set of stage 2 5.7L heads the intake volume is approx 228cc and exhaust is approx 85cc and we use 2.055/1.60 size valves
Thanks for the info Brad. Yes, I have the 78mm LSX. With a stock motor, I couldn't see getting the bigger one, and I have no plans right now to go to a stroker motor. Whether I stay with the Hot Cam, I can't say. I can see wanting to go bigger later after I get into the road racing. Tho I do LOVE it's idle!!!
So I guess that means I should consider stage 2s for future growth potential. I can always put in a stall to keep the rpms up. Nice pics by JRP....great craftsmanship!!!
