Dominator Cam Special
LS1TECH Sponsor
I have 4 Dominator cams received on a special purchase from my cam supplier. This is the same cam that made 502rwhp / 437lbs/ft rwtq on a 346CI pump gas LS1 with our Dominator top end package.
The cam specs are 242/250/109 0.578/0.578
This is a nasty cam. Price on these 4 is $370. They go back to $425 after these are gone.
Thanks!
Mikey
Thanks!
Mikey
Originally Posted by mikey
If it is tuned correctly it can be daily driven.
2 are sold. I have 2 left.
Well I get paid friday and if theres still 1 left ill order it. Do you have an cam only dyno numbers in an A4 but m6 would be good to. What kind of stall would u recommend with this cam and are arp rod bolts required or is that just with the heads and cam? I have comp 918 springs with the blue stripe are those good enough?
LS1TECH Sponsor
No cam only numbers with this one, sorry. Stall should be in the 4400 area and the blue stripes should work although I would sell them and go with the Crane duals.
I'm definitely interested in this cam, what were the specs on the heads that made 502RWHP? I have a set of stage II LS6 heads milled 15 thou. on a stock bottom end. Would this cam fit without flycuts? I don't care if it's tight as long as it doesn't hit. I'm interested since the lift is noticeably less than all these other big cams I see that have over .600 lift on the intake and exhaust.
Let me know what you think. I had 200 thou. valve drop on the intake if that helps? Thanks.
JF, The heads were LS6 heads cut 0.030. P-V was close but (about 0.050) but manageable.
I still have 2 left.
Mike
Mike
Thanks!
LS1TECH Sponsor
Cool Joel. I'll be in and out all day so just leave me a message if I'm not here.
fastblacksixspeed: I can get you the cam, crane duals, ti retainers, steel seats, valve seals and pushrtods for $999. Usually $1195.
Z28Maro: here you go: http://www.rapidmotorsports.com/mode...=1&intYearId=3
Thanks guys!
Thanks guys!
Tried calling a couple times couldn't get a hold of you, left you a message on your machine. I sent you a PM.... Give me a call sometime today or over the weekend if you can - I'd love to get this cam by next week some time. Thanks!!
