Nitrous Outlet Christmas Specials
We are approaching the count down for Christmas. Everyone is searching for that perfect gift. Here at Nitrous Outlet we have made your choices a little bit easier with some KILLER Christmas Specials. Suggest Nitrous Outlet whether you are looking for something for your self or some one else!
Complete System Packages
Group 1
LSX Car Plate Systems
Nitrous Outlet LS1/LS2 plate system with 10lb bottle.Your choice of 78mm or 90mm.
Automatic bottle heater
Nitrous pressure guage
Fuel pressure safety switch
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Digital dual window switch; wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
Also includes (8) NGK TR6 spark plugs.
![](http://img230.imageshack.us/img230/8645/group3nd8.jpg)
COST- 1,115.00
Group 2
LSX Truck/SUV Plate Systems
Nitrous Outlet LS1 78mm/90mm truck plate system with 10lb bottle.
Automatic bottle heater, nitrous pressure guage, fuel pressure safety switch, NHRA fitting, blow down tube, purge kit, and nitrous filter.
![](http://img264.imageshack.us/img264/9725/group6rc2.jpg)
Cost-1,150.00
Group 3
LTX Plate Systems
Nitrous Outlet 52mm, 58mm, Mono Blade LT1 plate system with 10lb bottle.
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
![](http://img440.imageshack.us/img440/9229/group11iu9.jpg)
COST-1,115.00
Group 4
GTO Dry Halo system
Nitrous pressure gauge
NHRA filtting
Blow down tube
Automatic Bottle Heater
Nitrous Outlet purge kit
Nitrous Filter
Digital dual window switch;wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
NGK TR6 Spark Plugs
![](http://img211.imageshack.us/img211/6889/group8jd2.jpg)
COST- 845.00
Group 5
(For you 98-02 F-body guys)
F-Body Halo system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
![](http://img501.imageshack.us/img501/9712/group7az4.jpg)
COST- 845.00
Group 6
Nitrous Outlet Dodge 5.7/6.1 Hemi Plate system
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Image Comming Soon
COST- 1,100.00
Unforgettable Deals
1. Brand X Single Nozzle Dry System
Adjustable 35-150hp
Image Comming Soon
Introductory/Christmas special
Only 269.99
2. Brand X Single Nozzle Wet System
Adjustable 35-150hp
Image Comming Soon
Only 299.99
3. Brand X Purge Kit
Image Comming Soon
Only 55.00
4. NX Power Booster
![](http://img263.imageshack.us/img263/4596/powerflyercopyzj6.jpg)
Only 5.00
5. Nitrous Outlet F-body Switch panel.
Three switch design. Controlls System Activation, Heater, and purge.
Mounts in ashtray area.
![](http://img150.imageshack.us/img150/4440/9802fbodyinconsole3swicht9.jpg)
Only 49.99 Excludes special below
5. Custom Aluminum Bottle Bracket
![](http://img440.imageshack.us/img440/1410/3d6b1yw4.jpg)
![](http://img261.imageshack.us/img261/7981/2d191fz7.jpg)
Natural Finish- Only 159.99
Anodized (Clear, Red, Black, or Blue)- Only 185.99
12 Great Stocking Stuffers
All Stocking Stuffers Are 10 Percent Off
1. Nitrous Outlet or Beer Custom switch panels.
2. Nitrous Outlet custom solenoid Brackets.
3. 860 Hex to wing Adapters
4. 860 V spray Purge
5. Nitrous Outlet Billet Wide Open Throttle Switch’s
6. Nitrous Outlet Tranny Tunnel Bottle Bracket
7. Nitrous Outlet GTO Bottle Bracket.
8. 860 Spare Tire Area Bottle Bracket
9. Nitrous Outlet Glow in the dark Bottle Pressure Gauge
10. Nitrous Outlet Automatic Bottle Heater
11. 860 Performance Heated Bottle bracket Combo
12. Nitrous Outlet T-Shirts
These specials are good until the end of December.
You can call in your order toll free at 1-866-648-7637
Merry Christmas
Thank You for your support
Dave
Group 1
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
COST- 1,115.00
Group 2
Cost-1,150.00
Group 3
LTX Plate Systems
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
COST-1,115.00
Group 4
GTO Dry Halo system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 5
F-Body Halo system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 6
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Image Comming Soon
COST- 1,100.00
Unforgettable Deals
Adjustable 35-150hp
Image Comming Soon
Only 269.99
Adjustable 35-150hp
Image Comming Soon
Only 299.99
Image Comming Soon
Only 55.00
4. NX Power Booster
Only 5.00
Merry Christmas
Dave
Devil Dog, OohRah!
Damn you guys! I was hoping to be done spending money on my car for awhile! ![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
What is the difference between Group 1 and Group 5? Is one dry and the other wet or something? Will that 10 pound bottle fit where the spare tire goes? Can I get that nifty ashtray switch set with a fourth switch for a remote bottle opener? It seems like a damn good deal for a complete system with all the safety stuff.
Just answered your questions in the nitrous section.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Dave
