gm9-aux adapter installed..need help
The only thing that I noticed was that it took 30 seconds for the sound to start after it was first connected it. I've had to disconnent and reconnect it a few times due to headunit replacements (unrelated issues) and it exhibited the same delay each time. Other than that initial delay, its worked fine.
Strange little device!
If you do, I had this problem, the Inline plug was not going in all the way,
Had to use a thinner plug because the Antenna & power cord got in the way, causing the inline plug to not go in. Thus only getting sound on the drivers side only and a high pitched distortion sound.
If this is not it, check the GM9 unit making sure the plugs are all in all the way.
Hope this helps
Gary
https://ls1tech.com/forums/showthread.php?t=682442
I spent roughly $150 for wires and adapters to connect my Pioneer XM receiver into my car for a stock look. If I was doing it again, I'd probably put that money towards an aftermarket headunit.
If you are wondering what I spent $150 on:
http://www.fadingarrow.com/XMSatelliteRadio.htm
