S2000 vs. WS6
#81
***Repost Police***
why doesnt it run 6 seconds? and any car no matter the engines size do enough to it you can pump out enough hp/tq to pull the wheels up. just curious How much does that car weigh? esp at the front wheels. i bet its does not have to lift very much compared to a lot of other cars
and as long as a larger Engine gives more HP to weight it is going to be more beneficial than a smaller liter engine. and yes you may stay at 6k rpms and stay withing your powerband but if you still have gutless tq at your high Peak power RPM then it doesnt matter.
i love the look of the cars. and think there nice cars. but i will never consider it a good platform for a straight line performance car. iIlaugh when people bring up "well it can own you in turns" because a VERY low % of people race there cars in turns in closed courses.
#83
You are an idiot, you prove it in every damn thread.
#84
What people need to look at is there dyno. Look at the power under the curve. How long do you make good power? 2-3k rpms? Say you make good power at 2500rpms and redline at 6500. So you have 4000rpms of good power. Now in my car I make good power around 5500rpms and readline at 10000. So I have power for 4500rpms. Who cares where you make as long as you make it for a good bit.
If a "4 banger" cant make tq please tell me why InlinePros s2000 pulls both wheels off of ground on the start????
And there's no way that any S2000 is going to pull the front wheels unless its completely gutted and weighs next to nothing or its turbocharged and its launching in boost. Thats obvious.
#85
***Repost Police***
And no stock S2000 makes power at 5500 nor redlines at 10K. They make power at 6,000 to about 9,000, which is a very narrow powerband, and it takes forever to get up there. So if you find yourself in the wrong gear, the race is over.
#86
I owned a Mustang that handled very well, thank you. If you couldn't tell (which obviously you couldn't), my post was a bit sarcastic. I don't think it's stupid to road race or auto-x F-bodies and Mustangs, just like I don't think it's stupid to drag race S2000s. Reading comprehension > you.
Takes forever to get to 6,000rpm? No. When I take off from a stoplight the car is at damn near 3,000rpm by the time I have the clutch all the way out. The only way it "takes forever" to get to 6,000rpm is if you try something like trying to race somebody from a 30mph roll in 3rd gear. If you drive the car like it's supposed to be driven, you rarely find yourself in the wrong gear. You talk so much about "daily driving," but then switch to racing whenever you see fit. If you are racing somebody, why would you be in the wrong gear?
Its easy to be in the wrong gear. Some things catch you off guard, like ricer flybys. I usually just walk them in whatever gear I'm currently in, no need to downshift to get into a peaky powerband.
#87
***Repost Police***
There was no sarcasm in that post. You basically said that its silly to drag race S2000's just as its silly to road race F-bodies and Mustangs, based on that attitude.
3000RPM by the time the have the clutch out?? Have fun replacing that clutch, its not long for this world seeing those kinds of RPM's from a stop in daily driving.
#88
sorry but that is extremely wrong, they are slow as *****, but a properly setup turbo one with a nice tune can make upwards of 550-600hp if the owner has the ***** to push it.
#89
Considering the stock clutch in this car has over 83k miles, you're wrong on that too. It's not as strong as it was 60k miles ago, but it's got some life left in it.
A clutch is a simple mechanical device that wears at a rate entirely dependant on slippage and heat. Its simple physics that the more you slip it, the faster it will wear.
I take off from most stops between 1200RPM and idle. Thats all that is needed. Taking off at 3,000RPM in daily driving will put some serious wear on any clutch.
And ricer flybys are usually done on the freeway from what I've seen, so you "usually walk them in" when you're cruising in 6th gear? Good luck with that. It hardly takes ANY time to downshift, sounds like you're just lazy.
#90
***Repost Police***
I can think of more than one S2000 around that's over 500rwhp with EVERYTHING on the motor stock. Even has the stock headgasket (some people run a thicker headgasket to effectively lower compression).
#91
You aren't making anything close to 550-600HP without completely rebuilding the motor with forged internals and the works, which is extremely costly.
#92
***Repost Police***
Yep. 6th or 5th gear. When I was doing backroad runs with my friend in his STI, I was right behind him the entire time and I never downshifted below 4th gear. He was rowing gears like a madman, in most turns he had to go down to 2nd to keep it on the boost. Once again, the benefits of a fat powerband.
#93
***Repost Police***
#94
And I can go out and get a Procharger and put down 700WHP like its nothing, doesn't mean ****. No 2.0 4 banger pushing that kind of power without being fully built is going to last very long at all.
#95
6th, probably not.
#96
***Repost Police***
You sound like the kind of tool that always pulls out the "Well let me slap a blower on my Trans Am, and then see how that Cobra does" argument. But I would LOVE to see a stock LS1 run 700rwhp for any amount of time.
#97
Thats what I JUST ******* SAID. Putting down the power DOESN'T MEAN **** if its not going to hold it for any sustainable period of time. Hence my example. Learn to comprehend.
#98
***Repost Police***
#99
Boy do I love my LS1/RWD though.
so in the end, you win.
#100
***Repost Police***
I would love it if my car had a V6 or V8. But it doesn't. And at this point, handling is more important to me than a ton of torque. The convertible part is a big plus too.
