C6 Z06 vs 524whp EVO 9 vs 485+whp STI (vid)
#42
I don't give props to ricers.
Anyone who mods their 4 cylinder import to the point where its making that kind of power is either stupid, ignorant, or both. No 2.0L Mitsubishi is going to hold that kind of power for long, especially on stock components.
Its kind of like running down the track on a 200 shot, sure you may be able to do it and pull great numbers, but that doesn't mean its going to last.
If you want to go fast and do it right, you don't buy a Mitsubishi.
And by the way, I own a 4 cylinder turbocharged car, so its not like I don't understand these cars. Its a good daily driver, nothing more. Modding it to beat Z06's retarded, there are much better ways to go fast. And none of them involve 4 cylinders or transversely mounted engines.
^I'm guessing it's a FWD turbo 4 right? Thats the problem ricer, get a real car.
Well, at least i'm unbiased about the situation. It was a good run regardless. If you lose to an evo, do you make excuses and talk **** Wesman? If so you are more the ricer than the guy driving his car. How do you know his car is built improperly or on stock internals?
#43
#50
Why don't you ask your wife is she thinks Evos are the ultimate race car, then when she says no, your drunk *** will probably whoop her ***.
White trash is bad enough, ricer white trash is even worse. Better yet, eurotrashed, drunk, white trash ricers like yourself really lower the bar for everyone.
#51
Still would be a good challenge since you should be able to walk him from a roll. Would only be natural to go from a dig after that to see where you too would come out at about 130mph.
#52
http://www.youtube.com/watch?v=H_kT6kjKkx4
http://www.youtube.com/watch?v=R9WtwXROf1M
http://www.youtube.com/watch?v=IZx32APqUXM
even though they are 4 cylinder, but these engines are great... and you can get some nice power out of these and still be a DD with no problems if done correctly.......
#54
well I guess then there are a lot of "stupid, ignorant, or both"
Heres what you fail to notice:
Cammed out 4 cylinders don't run well on the street.
Huge turbos have horrible turbo lag.
Full built, boosted up, giant turbo 4 cylinders get horrible fuel economy.
And best of all, "reliability" is not a term in their vocabulary, because they are always blowing up.
I don't see whats so hard to understand. Building up a riceburning 4 cylinder to go fast is like pissing in the wind, you are just wasting your time.
And BTW, all those pieces of **** sound so bad that they make me want to cut my ears off...
#56
You can't fix stupid, people would make horse and buggies fast if they could.
#57
Thats why I said you are too damn stupid. Everything goes over your head.
#58
You can talk all the **** you want but the truth of the matter is that no one likes you, no one is backing you up, and it's becoming quite pathetic and predictable how you act.
And for the record, I like BMW's, just not the stuck up idiots that drive them (you).
You are good for a laugh as you are the type of car enthusiast I detest the most. You couldn't find any merit in a car unless it is a GM, Chrysler and maybe even a ford. If it's foreign you hate it like outside influence in your bible belt.
When you actually work on a car yourself, then try and open your mouth. Until then, keep watching Youtube and thinking that you know everything there is to know about building a fast car
#59
well I drove that evo on the streets and let me tell you, it is by all means a DD. full boost at around 3900 RPM, I wont really call that a horrible lag. and even though it has cams, still drive really nice on the streets with no issues of any kind...
as I said, if its done correctly, you wont have any of the issues you mentioned above.... you don't have to have big turbos or big cams, this is not the case where "bigger is better"...
it all depends on who build the car and why and where he want to use it...
yes you will lose some mpg (as in any car you want to make it fast) but well you have to pay to play.... if you want your car to be fast, you have to lost some mpg... never saw a car that gained power and mpg at the same time... true some loses less than other...
and believe me, if done correctly, it will be reliable just like any other modded car on the streets
and this is coming from a guy who never owned a jap car
all chevy vvvvv
all chevy vvvvv
#60
Think about it, this is not rocket science. Each cylinder on the Evo displaces .5L. So at 500WHP, each cylinder is making 125HP. That means 125HP for .5L, or 250HP per liter. Thats is an EXTREME amount of stress on the engine, regardless of the engine's internals. A Z06 at 500WHP is making 62.5HP per cylinder, or 71HP per liter. Thats a ton less stress, and the Z06 uses forged internals and dry sump oiling stock. Not only that, but a V8 is naturally balanced by its counterweighs, whereas a 4 cylidner is 100% unbalanced, creating horrible harmonics unless dual balance shafts are added. Most ricers remove balance shafts if they are there to save power, which proves how retarded they really are.
Only an ricer moron would claim that making power with a Mitsubishi 4 cylinder is preferred to making power with a real engine, such as an LS7. And sadly, they are out there.
