Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
Here's what the V is getting:
2.5" pulley
ZL1 Solid S/C Insolator
100mm idler pulley
9.55" crankshaft ring, LSA idler relocation bracket, 50mm double bearing idler pulley
ID850s
CAI
2" headers and cats to fit stock exhaust
8 rib belt
LS trunion upgrade, valve springs
3 bolt smooth cam
Crankbolt
LS3 hard pushrods
Cam sprocket belt, front timing cover gasket, front cank seal, bolt camshaft timing chain, water pump gasket and the actual timing chain.
2.5" pulley
100mm idler pulley
ID850s
CAI
8 rib belt
3 bolt smooth cam
Crankbolt
LS3 hard pushrods
Guess so.
I just asked for a reliable powerful build. He said this is very reliable and will net me 200rwhp over baseline. He will be tuning on 87 octane b/c of my octane restriction down here. I bet on VP I could net a **** ton more.
Cam is going to be quiet thus why I am keeping factory mufflers. Don't want the car to sound. Want my sleeper. No one has a CLUE to what a CTSV is down here. Going to ruin the party for lots of Ferraris and lambos.
1 Post
2.5" pulley
100mm idler pulley
ID850s
CAI
8 rib belt
3 bolt smooth cam
Crankbolt
LS3 hard pushrods
2.5" pulley
100mm idler pulley
ID850s
CAI
8 rib belt
3 bolt smooth cam
Crankbolt
LS3 hard pushrods
Muffler delete would sound bad ***, but I'd probably go more for cutouts then muffler delete. Good to keep a bad *** 4 door sedan quiet and surprising... especially if no one knows what it is out there.
Charge up the GoPro.
This. RPM definitely does badass work on V2s
That should be good money right there. Your crappy *** gas in thirdworldistan is going to suck ***, but that car should be reliable as all hell.
Electric Cut outs!!!
and to go with the meth, a couple snails to go in place of the blower.
no its not, we want a race car....
shooting for 1200+ whp? sounds like a solid plan!
