My Talon vs lS3 C6
#61
That was my first motor, second was 6 bolt, then a 2.3 stroker. My buddies had 6 bolts. The only friend that still has his only does because he has too much $ into it to sell it. Over 40 k, seriously. G4CS 2.4 block, best internals, stage 5 Shep tranny, Fp Black full kit, Standalone, full cage, ect..... Hasn't ran in like 6 months, got tired of towing it back to the shop.
#62
I've DD'd mine for the past 3 years. Every time it's broken has been completely my fault.
#63
As far as I'm concerned, any good videos or kill stories are allowed on here regardless of the make, model, or origin of the cars involved. And if there's an LSX in the video, so much the better, but it's certainly not a requirement. Post away. And nice runs. You've got a quick car there but those LS3's are strong!
#64
i also want to point out. that car that u posted up that dynod 440...
thats an FP manifold. and FP 20g a Sheet metal intake manifold.. sounds like a full bolt on stock block motor. with 2g pistons whic bumps compression. which will make significantly more than my car. just thought id point that out.
#65
#66
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#67
Couldn't agree more, I dd my old auto gsx that would trap 130+ and it never broke unless I beat it to death. Reason most dsm'ers complain is because they are cheap. Fast, cheap, reliable, pick two. Almost all dsm people go for fast and cheap. **** I worked on my friends car that was trying to break into the 8's and he would break constantly and not get why, turns out he won't buy expensive axles, transfer case, or driveshaft to support the hp. All were stock ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#68
thats kinda what ive seen be the case with this car since i got it.
ive found half tightened mount bolts
the lower control arm bolt was backed out a half inch.
coolant pipes not bolted down.
so many issues with the PO installing. its no wonder they get a bad name.
however this car, even with the odd issue im trying to figure out(buzzing noise with no start, but then starting after a bit). it still drives me every where everyday, and the only thing that has broken was the turbo from the 100k miles it had plus the PO has the BOV wayyyy to tight and compressor surged it every time.
other than that, this thing has been on the road every day, and been fine and fun. adnyhting thats messed up has been a direct relation to something someone did. and by no fault of the car itself.
i just hope i can fix everything before the car breaks it lol
on a side note.
28psi is only the initial hit. i was able to make a good pull and reallly watch the gauge.
it hits 28 on spool. then tapers off to 24.
as my RPM increase my boost decrease causing my injectors to be able to keep up lol. so if you were to see this on a dyno graph, it wouldnt be a nice steady increase, it would be more of a plateau. its like the car knows its cant run 28psi at higher rpms and lets the boost down because from like 4500-7500 its 90-95% IDC. it should be consistantly rising. but i think its from the weak hahn 8psi WG spring. anything above 24psi and that thing just doesnt seem to be able to regulate. so hopefully i can get a new one or do the washer trick and see if i cant figure it out.
on a side note.
#69
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
http://youtu.be/cjU_Ff1HIjc
my bad i dont hate subies but i was at the 2011 subaru shootout and i think my car was like the 3rd fastest there lol. For the most part mod for mod they just don't make the HP a DSM or Evo makes. A DSM with a 70mm 42R on E85 is no joke lol.
I think a 50 trim makes a tad bit more than a 20g. Add cams etc you could hit 500whp
#70
#72
My 30R won't hold over 26psi near redline. I have big cams, heavy port work and a sheet metal intake, but the point is i have a good deal more turbo flow than a 20G and i can't hold 28psi to the limiter.
#73
