Mach at the track
#2541
Well I plan on going to http://houseofhook.com/ as soon as I get some things done to the Mach. Hope to leave with a 11 second pass @ 108mph.
Yall game?
Yall game?
#2542
When will you get the factory motor back in it and ready to run? I still think you are making a mistake for running another factory motor but I understand why you are doing it. $$$$
#2543
Yea going to make sure it has enough fuel this time. Would love to get 600 out of a stock block.... I'm damn sure going to try!!!
#2544
#2547
#2551
#2553
#2554
#2555
It finally lifted the ring land on the #3 cylinder after a hard month and a half of 13lbs of boost.Never had it on the dyno at 13lbs put my tunner said it should have been in the 550 range at the feet.
#2557
What rpm you turn it? My friend only turns his turbo Mach 6000. he has thought about turning his limiter up....but with it showing issues he may not.
#2558
Pure stupidity killed my motor!!! Lol.... against my tunners advice I turned the wick up 2 more lbs. Had it not been for that it probably lasted a lot longer... killed the 3 vettes 1 camaro and 2 gt500's before she called it quits. I was only turning it to 6100
#2559
#2560
