Street Racing & Kill Stories Basic Technical Questions & Advice
Mach at the track
Old 05-02-2013, 12:33 PM
  #1801
HioSSilver's Avatar
Originally Posted by 92cobranotch
hiho, your hydrulic **** has no adjustment. i never said anywhere the hydrulics were to blame just said they were junk. i prefer cable over hydro. plenty of fords out there shifting over 6800 without issue. how ever id never own another ford engine.
Why do you want to adjust a clutch that adjusts automatically? How often have you adjusted your f-body clutch?? I don't adjust mine. From a new clutch to a slipping clutch there is no reason to adjust it.
Do you realize you couldn't even push the clutch in your car if it was cabled Mustang?
FYI.....I know how and what to do if I wanted pedal height to adjust. I also know what to do to make the throw longer, shorter, harder or softer. Some of which can't be done with the cable w/o major mods...if at all.
Originally Posted by Mike Morris
Id take the Ford cable set up any day over the Fbody set up. Easy to fix and upgrade.
Shut up mike.......you can suck it
Don't let the hydraulics scare you. I don't do **** to mine. Basically it has not even been bleed since 06 or 07 when I put the system together. Mastercyl was put in back in 01 or 02.....to solve a clutch issue which it didn't. That's when I knew it was a pp issue.
HioSSilver is offline
Old 05-02-2013, 12:36 PM
  #1802
big hammer's Avatar
I bet the 5.0 guys wish they had a cable.
big hammer is offline
Old 05-02-2013, 12:38 PM
  #1803
S8ER95Z's Avatar
I know I wish they had one... then maybe they would have cable issues and I could actually beat one.
S8ER95Z is offline
Old 05-02-2013, 12:41 PM
  #1804
big hammer's Avatar
they're slow.
Old 05-02-2013, 12:44 PM
  #1805
evangto87's Avatar
I wish i had a cable driven clutch... my trans might still have a fifth gear syncro if it did....
evangto87 is offline
Old 05-02-2013, 12:48 PM
  #1806
HioSSilver's Avatar
tell me how you figure that?
Old 05-02-2013, 12:49 PM
  #1807
big hammer's Avatar
supposedly those cars have hydraulic issues.
Old 05-02-2013, 12:50 PM
  #1808
evangto87's Avatar
ill pass...
  #1809
HioSSilver's Avatar
I bet you guys ride around pulling your e-brake to slow down. I mean **** you like cables right?? No need to use those HYDRAULIC brakes......lmao
  #1810
evangto87's Avatar
yes sir.. I think you may have experienced it in your friends boss...
Old 05-02-2013, 12:52 PM
  #1811
HioSSilver's Avatar
Is it a hydraulic issue or clutch issue?
ill pass...
Why?
Are you compressing the fluid with your massive legs and don't want to tell us?
Old 05-02-2013, 12:54 PM
  #1812
big hammer's Avatar
yup. it's pretty bad actually. he just pulled it out of storage so i'm going to try your pump up trick to see if it works.
Old 05-02-2013, 12:55 PM
  #1813
big hammer's Avatar
Why?
hydraulic supposedly. it's like the clutch doesn't fully disengage at high rpm.
Old 05-02-2013, 12:59 PM
  #1814
evangto87's Avatar
^this.
It got better with the braided clutch line. But i still have to pump my clutch to hit a 1-2 shift with ease. I also dont like how the clutch fluid is tied in with the brakes.
Old 05-02-2013, 01:06 PM
  #1815
adamantium's Avatar
From termi swaped notch to bolt on f-body, says he'll never go back to a ford engine. Umad stoppyautmachheateretc...
adamantium is offline
Old 05-02-2013, 01:10 PM
  #1816
evangto87's Avatar
let them start playing with new 5.0s... i think they would be lieing to themselves if they hated on it. I hated working on my buddies 03/04 cobra motors... just a giant mess of a confusion and parts/pullies.
I went from various LS/LQ stuff.... i love the ever living **** out of my roadrunner. Technology is a bitch! Its a simple motor. Not quite as simple as push rod motors... but as simple as a mod motor is going to get. Theres a reason its 300lbs lighter then the ALUMINIUM 2013 GT500 long block.
Old 05-02-2013, 01:26 PM
  #1817
Poppacapp's Avatar
Problems with clutch not fully disengaging? I think that is my issue mainly on 2nd gear. I am having a McLeod RXT twin disc installed and the mechanic mentioned putting a spacer behind the slave cylinder to allow more length to fully disengage.
Poppacapp is offline
Old 05-02-2013, 02:08 PM
  #1818
S8ER95Z's Avatar
That was great...ahahaha
Same issue I had... the pressure plate was fubar both times. First time it just wouldn't work above 5K.... the little metal weights snapped off...
the second time the damn thing cracked in a couple of places and wouldn't shift above 6K. GM quality FTW!
S8ER95Z is offline
Old 05-02-2013, 05:27 PM
  #1819
Tech Apprentice
Stopsign32v's Avatar
Stopsign32v is offline
Old 05-02-2013, 05:55 PM
  #1820
Puck's Avatar
^this.
Granny shiftin', not double clutchin' like ya should.
Puck is offline
Quick Reply: Mach at the track
