Street Racing & Kill Stories Basic Technical Questions & Advice
ls1 Trans Am vs 2014 5.0 Coyote
Old 05-01-2014, 11:27 PM
  #441
Blown383LS1's Avatar
Originally Posted by bh353
Ok dumbass..How far can you oversize a 5.0?Please tell me the max bore and stroke..because im gonna drag your *** down the street with your lame *** answer..
Originally Posted by OneSlowV
Pretty sure you can turn one into a 351 witch would be cool. But cost to much money.
Are you going to drag his *** down the street now?
That's it?...351? so where do you think you ca bigger cube's?..thats right dumbass a bigger block..and it ain't fitting in a mustang with those big *** heads...
351ci with a 5.0 block. You sir are retarded but at least Hio is on your side, lol.
Old 05-01-2014, 11:28 PM
  #442
bh353's Avatar
Originally Posted by Irunelevens
Fair enough.
He was saying that you don't have to increase the block size to increase the displacement.
Why are you comparing deck height of a engine?..Has nothing to do with displacement...
Old 05-01-2014, 11:29 PM
  #443
HioSSilver's Avatar
How am I on his side? I just corrected gt4
Old 05-01-2014, 11:30 PM
  #444
bh353's Avatar
How about this 427 with a Ls1 block...who feels retarded now?
  #445
Originally Posted by HioSSilver
Not really....they need sleeves to do it. It don't go there willingly.
Can you give me an example of an engine that increases it's displacement "willingly"?
Old 05-01-2014, 11:31 PM
  #446
HioSSilver's Avatar
It can and usually does....but not always. Deck height usually coincides with a increase or decrease in stroke.
Old 05-01-2014, 11:34 PM
  #447
I don't, do you? Again I ask, my bores measure 4.125, how much boost can I handle?
Old 05-01-2014, 11:36 PM
  #448
HioSSilver's Avatar
Sure....about any of the ls stuff will take a 4" stroke easily. It's not like you need to sleeve them. You have several bore sizes to choose from also if that's what you want. Or you can change the engine and go from a 4.8 to a 7.0. With no aftermarket needed.
I know you understand what I meant.....why be a dumbass?
  #449
bh353's Avatar
Deck height coincides with how far the piston comes out of the block...which normally will raise compreesion,but not increase displacement without a stroked crank...
Old 05-01-2014, 11:40 PM
  #450
bh353's Avatar
I don't care how much boost you can handle...But I can tell you all ls blocks are the same size except for the bore...
Old 05-01-2014, 11:43 PM
  #451
Thanks for the tip.
  #452
HioSSilver's Avatar
Not really but kinda. You're thinking more of decking the block. Which will more than likely will bring it closer to it's true deck height.
Allot of fords for instance have the same bore size. They vary the displacement via deck height and stroke.
Chevy also had a 427 tall deck motor. It was mostly used in school buses and dump trucks. Smaller bore longer stroke than a standard 427 yields a similar/same displacement.
Old 05-01-2014, 11:52 PM
  #453
bh353's Avatar
Well yes, the taller the deck the more displacement it will have because of volume in the cylinder..but usually yields lower compression..
Old 05-01-2014, 11:59 PM
  #454
HioSSilver's Avatar
You need to do some reading bh3
Old 05-02-2014, 12:01 AM
  #455
***Repost Police***
Irunelevens's Avatar
That's obvious
Old 05-02-2014, 12:03 AM
  #456
bh353's Avatar
Are you talking about the height of the bore or how far the piston comes out of the bore? im talking about how far the piston comes out of the bore..
Old 05-02-2014, 12:16 AM
  #457
He is talking about reading up on engines period.
Old 05-02-2014, 12:20 AM
  #458
bh353's Avatar
That's obvious
You have no clue what you are talking about...do you even own a car? I have built more racing pwc engines than you are old and your gonna talk to me like I don't know what im talking about when it comes to engines? Anytime you would like to get a lesson let me know..
Old 05-02-2014, 12:23 AM
  #459
bh353's Avatar
Yeah ok...I know more about engines than you do apparently.
Old 05-02-2014, 12:26 AM
  #460
You know more about pwc engines maybe.
Quick Reply: ls1 Trans Am vs 2014 5.0 Coyote
