Street Racing & Kill Stories Basic Technical Questions & Advice
calling out snake95\ other 5.0's!
Old 10-30-2014, 01:07 PM
  #401
snake95's Avatar
You "bet"? That's supposed to hold some weight?
snake95 is offline
Old 10-30-2014, 01:08 PM
  #402
R6cowboy's Avatar
Originally Posted by big hammer
I bet the DZ had as much power, similar redline but a broader power band. How is that possible?
Because stupid lazy engine of mismatched parts. Ford already proved that, where do you think they came up with that? By copying what Chevy did with their 302. Now quite asking questions you already know the answer to.
R6cowboy is offline
Old 10-30-2014, 01:27 PM
  #403
Heater's Avatar
Originally Posted by 408-99-f
A relative of mine is a self proclaimed "ford fanatic" he has a boss 302 engine and doesn't use it in any of his builds because he says the blocks are prone to cracking, and keeps it as a investment. I have also read that in a article in a magazine? I dont know if there is any facts to this, maby some one who is more fimmilar knows better than I. Just what I have heard/read??
Way back before aftermarket 8.2 deck height blocks, guys used the 302 Boss block, I've seen them run in the 7's and had never heard a issue of them cracking. The regular 302 blocks, yeah they have a issue with cracking.
They are bad *** blocks, probably a little heavier than what most guys would use now for racing, since aftermarket blocks are readily available and lighter.
Heater is offline
Old 10-30-2014, 01:34 PM
  #404
zz4camaro1980's Avatar
Originally Posted by snake95
My statement was explaining how .029 valve lift =/= same change as 26* duration.
Hammer's just trolling. No response necessary.
I should have been more clear, I agree with you but thought it was a bad analogy/way to prove the point.
Good luck to both of you, curious to see how this turns out. Can easily go either way.
zz4camaro1980 is offline
Old 10-30-2014, 01:41 PM
  #405
HioSSilver's Avatar
Originally Posted by R6cowboy
Fact is those specific Cleveland heads were indeed "better" than Chevy's Fuelie head. It's hilarious how you can never bring yourself to say that Ford had anything what-so-ever better than Chevy.
Hio, I want to ask you this. Did the DZ 302 have a better cam than the Boss 302?
I already stated the differences in the cam. Which one is better?? Who the **** knows..... The cam is what the manufacturers choose and I would assume they both thought theirs was the best for the application intended.
^^^Of course not. When proof is right in front of him than the Chevy design is worse, it's all "Well, I saw 4 other tests and the results can go either way". When he has some article or evidence of the contrary, it's "These are just facts and you Ford guys don't like facts."
It's like clockwork.
You don't like the facts. It's why you will try to continue say the boss is better when the facts are they were within spitting distance of each other. The facts are Chevy's 302 won back to back championships and ruled 1969 trans am series. The following year there was very limited support from gm to compete in that series. And having a new car means having a new development cycle.
HioSSilver is offline
Old 10-30-2014, 01:52 PM
  #406
R6cowboy's Avatar
I was just messing around with the cam question btw. No worries though man, just between me and you, deep down the Chevy 302 really is the better 302. Don't tell snake that though, he can't handle the troofs.
R6cowboy is offline
Old 10-30-2014, 02:01 PM
  #407
snake95's Avatar
R6 knows the only way to shut Hio up is to stroke his ego
snake95 is offline
Old 10-30-2014, 02:40 PM
  #408
ZNix's Avatar
I'm having dirty thoughts about a 3" stroke 4" bore LQ based motor with ls3 heads... just saying.
ZNix is offline
Old 10-30-2014, 02:49 PM
  #409
big hammer's Avatar
you can pretty nearly do it by boring out a 4.8
big hammer is offline
Old 10-30-2014, 03:10 PM
  #410
R6cowboy's Avatar
Too bad the shortest stroke for a LS based motor was 3.27"
How aboot 3.27" stroke 4" bore . Is that still grounds for said dirty thoughts?
R6cowboy is offline
Old 10-30-2014, 03:11 PM
  #411
HioSSilver's Avatar
I never really said which one was better. But if you let the head to head racing results speak for them then its easy to see. If that is how you determine which one is better, then fine. Those are simply the facts.
You're right about snake not handling the troofs.
so how do you determine which one is better?
Old 10-30-2014, 03:15 PM
  #412
Guitar's Avatar
Let the boy be, he's used to 3".
Guitar is offline
Old 10-30-2014, 03:16 PM
  #413
R6cowboy's Avatar
Honestly, between those two engines, hard to tell. Each has their own pros in a different way, which made them too evenly matched for myself to claim in my opinion which was better.
R6cowboy is offline
Old 10-30-2014, 03:26 PM
  #414
snake95's Avatar
The GM 302 fell off the face of the earth after 1969, that's how you tell.
snake95 is offline
Old 10-30-2014, 03:31 PM
  #415
HioSSilver's Avatar
I agree. But like said..... if you look at the racing end.....well... it speaks for itself
Lol at snake reaching.
Old 10-30-2014, 03:35 PM
  #416
snake95's Avatar
Hio no likey the facts.
snake95 is offline
Old 10-30-2014, 03:58 PM
  #417
big hammer's Avatar
And the Cleveland headed 302?
Old 10-30-2014, 05:28 PM
  #418
HioSSilver's Avatar
snakey no likey the facts.
Old 10-30-2014, 05:32 PM
  #419
snake95's Avatar
Throws head specifics on it to detract from the truth, if the motor was worth a **** why did they scrap it altogether?
Ford still produced a 4x3 302. Where's GM's?
You tried, anyway.
snake95 is offline
Old 10-30-2014, 05:34 PM
  #420
codyvette's Avatar
Y'all will debate for days over **** that should be over in a matter of minutes. They were a great stepping stone for there time but they are both pieces of **** in comparison to what we have today. That's why they stopped making them. You people do realize that these engineers jump ship on regular basis and steal **** from one another constantly, right? The actual companies just pay them. Y'all act like mister Ford and mister Chevrolet are in some great challenge together. They are dead.
codyvette is offline
Quick Reply: calling out snake95\ other 5.0's!
