calling out snake95\ other 5.0's!
#121
Just as I suspected, when outgunned, you try to make your race car sound like something anyone could do in their garage on a weekend.
You've thoroughly embarrassed yourself yet again
I've spelled it out as clearly as I could, if I had an E7 headed car I would gladly do the bolt on thing, I have the one year where they used E6s, and let's not forget, zero part of hammer and my challenge will change the fact 302s drug 305 bumpers off throughout the fox era. You wish it wasn't true so much you are delusional about it.
Wake up, little Dougie. This challenge isn't what you would do with a 305 car and a holesaw.
If you're trapping 130, you should be deep 10s, but I guess you can't drive worth a **** even though you have a faceplated tranny that shifts like a knife through hot butter at WOT.
Modding God for sure
How you continue to type after embarrassing yourself day in and day out is an amazing display of persistence, for sure.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Lol drives a 14 sec ride
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#130
Cool so you think a bolt-on ls6 should go deep in the 10's after saying my times/car/mods are bs. Awesome. You should feel stupid enough about all the **** you have talked now.
So your furd parts won't keep up with a 305 after all the **** you talked about 302's dragging around 305's........check
My car is easy to build, it's not like I had to research what aftermarket heads to use to keep up with a 305.
Hell most do **** way more extreme than me by removing hvac ****, bumber supports, cruise and radio crap. I still have all that. A fp'd tranny is nothing more than a shift kit to a auto. 5-6 gear still there and sycro's, same with reverse. You just want something to cry about.
So now you take pot shots at my driving after totaling your own car??? That's just ******* laughable.
And again....I expect not to hear anything about my air bags or you would have bought a car with air bags after ******* your **** up.
My post in the other thread was pointing out how I ran 15.1 @ 92 and hammer using his GPS testing ran slower at less MPH, of course you conveniently didn't see it, because you don't have **** to say
What does me totaling my car have to do with taking shots at your car? Are you really going to bring up my accident as ammo for your argument because you're so far backed into a corner? I though you had like, an ounce of class to you, but you don't. You're perceived as the resident ignorant redneck from the hills of Virginia, and that's because you are.
Also, I would never REMOVE air bags from a car. I had a 95 Cobra with airbags, kept them in, 86s didn't come with air bags and I like the styling considerably more than 87 and later years, NOT placing airbags in a car that didn't come with them is 100% different than you yanking yours out to run better times. Once again, you're trying to use my accident for ammo
#131
I'm sticking with EFI because this will be a true street car that is used to pick up groceries and cruise and ****. I'll be using stock ignition parts.
On a side note, I'm just marveling at Hio's ability to de-rail a thread when it was created for reasons that had ZERO to do with him. Having brain function comparable to that of a Neanderthal must be a ************.
#132
Just that even 6300 is very limiting when you think about the cubes(305). I have dabbled with 7000+ rpm small blocks (350)keeping them extremely streetable. Nothing like dumping the clutch at 8000 ha. Did blow a wheel off the vette it was in though. Shifting into second @ 55mph. Dam left wheel popped through the quarter panel and flew by my head spinning brake fluid in my hair(T-tops off). It then skimmed the side of the front fender leaving a light black mark then it shot a mile down the road right down the yellow line as the rear hit the pavement and I skidded into the local fire department.
#133
#135
Oh man, I'd love to rev this 302 to 7400 plus, but that's a lot of risk on the stock rotating assembly and block (for mine anyway, IDK how strong 305 blocks are), so doing that would be some $$$$. Plus, to take advantage of those higher RPMs, I'd need a cam that wouldn't be a whole lot of fun to cruise to dinner with the lady friend, etc.
looking at this so far.
Hydraulic Roller Cam. Fair idle, great low to mid range power for daily usage. Works well with tune port injection.
•Advertised Duration (Intake/Exhaust): 276/286
•Duration @.050" (Intake/Exhaust): 218/228
•Gross Valve Lift (Intake/Exhaust): .503"/.503"
•Lobe Seperation: 112
•Intake Center Line: 108
•RPM Range: 1800-5800
#137
Fixed that for ya
Not to mention all the **** talking he does about a 11sec ride but he has never left the 13's![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
If you have access to a lathe bore that bitch out and make new throttle blades.....or make it a oval![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
You're right....the motor in my car is nothing special....just a bolt on ls6. No h/c needed
But as usual you are lying about the weight among other **** you randomly make up. Funny how you straight up lie about my weight yet do not claim that the weight of a fox is why they go as good as they do.....hhhmmm Hypocrite much??.....why yes you do. So when you gonna weigh the fox.
If you are so worried about my safety then I would assume you would be more worried about yours. They made foxes with a airbag.....you could have bought one of those but instead you use the excuse you like the others better. No better than you can drive it would have been wise for you to do so......but you're not that wise. Your accident is ammo when you use my mods as ammo.....You fucked up bad just because you fucked up.
Your crying is what derailed it. I'm just here to watch hammer's 305 drag you. But I'm sure you will come up with some excuse for that.....just like not wanting corrected times cause you know your air is better.
The motor in your car is nothing special, it's weighing 2900lbs with a FP'd tranny and cut up **** that makes your car MPH well, and I'm saying it ETs poorly for the MPH.
Ford showing that 305 what's up, I can't wait to hear your crying on this one.
Meanwhile, you took out the most important safety equipment in your car to try to pick up ET and MPH...Joe Dirt engineering FTW.
My old setup revved to 6100 or so with small heads and intake and exhaust. With better parts, it will rev til 6300 or higher.
I'm already agreeing to 1/8th instead of 1/4th, I'm not doing corrected times. No ifs ands or buts about it. If I lose by 1 tenth, and would have won if times were corrected, that's how the cookie crumbles. The only reason I budged off of the 1/4 mile thing is because it'd be forever until I got to see his run, IF he even ran it at a 1/4 track, which if he didn't, this build-off would be useless.
#139
Fixed that for ya
#140
I would look to spin it harder with that intake.
