Street Racing & Kill Stories Basic Technical Questions & Advice
16SS vs gt500
Old Feb 19, 2016 | 05:07 PM
  #121
HioSSilver's Avatar
The only thing that generates the anti squat is the force of the tires rotating forward there for anti squat or bite can be generated by irs. Most are just set up near neutral for best all round performance. Then just like on a lowered sra car a lowered irs car will become more prone to wheel hop typically.....of course there are things that can affect that.
Sra cars can wheel hope too you know.
Old Feb 19, 2016 | 05:13 PM
  #122
HioSSilver's Avatar
Originally Posted by zz4camaro1980
I think this is where the confusion is coming from, (just as I did when I read your other post) I think ZNix is taking inertia from the drivetrain through the body into account. While you are talking rear end only... I've got to say, you've swayed me on the IRS vs SRA for drag racing, you make a valid point.
Just out of curiosity, does anyone know how much parasitic loss is associated with u-joints vs. a straight axle?
Thanks......just stuff to make you think. It's not so cut and dry anymore
Probably very little these days with most having cv joints and not u joints for rear axles. Sure there is probably a small weight penalty but at least the weight is unsprung and in the back. It also seems most differential cases are aluminum these days reducing the weight penalty associated with irs.....actually many of the componets are aluminum even the uprights.
Old Feb 19, 2016 | 05:34 PM
  #123
ThoR294's Avatar
Originally Posted by Bitemark46
I took you off my ignore since I'm not on here that much anymore.
You are correct in saying there are no forces on the drive wheels. That is caused by the bend in the u-joints of both half shafts. All that energy stops there. However by definition, antisquat is the action of the rear end wanting to point downward on the hit because the ring gear wants to nose over. Because all that energy is not transferred to the tires via a fixed non bending piece of metal, it pulls the body downward. So IRS cars have NO antisquat built in them. You have it backwards.
That is why IRS cars are more prone to wheel hop. There is no downward force being applied to the tires.
-Mark
Knew a smart rear guy would chime in. None other than my sig Buddy!
Old Feb 19, 2016 | 05:41 PM
  #124
Bitemark46's Avatar
Originally Posted by HioSSilver
Yes....that is what i was trying to explain to him irrelevant of the body. The irs with has the differential mounted to the body so there are no forces on the drive wheels other than moving the car forward sans anti squat built into it.
wut? So antisquat is a force that is created from the tires going forward? I think you are getting confused. Antisquat is a result of how the suspension (i.e. the lever or how much leverage) there is with respect to the rear. Too long of a lever (long IC) and the car squats. Too short of a lever (short IC) and the rear of the car rises too quickly then unloads.
When you say neutral...where would you put the IC to get the AS neutral? Trick question.
-Mark
Old Feb 19, 2016 | 05:43 PM
  #125
"MAC"'s Avatar
wut? So antisquat is a force that is created from the tires going forward? I think you are getting confused. Antisquat is a result of how the suspension (i.e. the lever or how much leverage) there is with respect to the rear. Too long of a lever (long IC) and the car squats. Too short of a lever (short IC) and the rear of the car then unloads.
-Mark
In his butt?
Old Feb 19, 2016 | 06:36 PM
  #126
marc97taws6's Avatar
Originally Posted by "MAC"
In his butt?
Wtf, Mac?
Old Feb 19, 2016 | 06:42 PM
  #127
Deeohgie69's Avatar
Lol... Ok
  #128
HioSSilver's Avatar
-Mark
Yes......but with no force applied it is all static. The tires apply this force and the suspension reacts to it.
Neutral would be the area that is best for acceleration and braking. Getting agreesive with either will detract from the other. This is also where irs shines because now it has one less force to deal with since the diff is hard mounted . Newer irs is usually multi link also which can better distribute these forces.
Times are changing......technology is changing. I just seen it coming before most. There will be a day when we look back at sra cars and be like what a diabolical pos that was.
Old Feb 19, 2016 | 06:45 PM
  #129
"MAC"'s Avatar
Originally Posted by marc97taws6
Wtf, Mac?
I was guess what doug does with gm stuff
Old Feb 19, 2016 | 11:06 PM
  #130
Bitemark46's Avatar
You couldn't get a more vanilla answer if you tried. I figured you didn't know the answer even though the answer had the word "neutral" in it.
Answer: Draw a line from where the rear tire meets the ground (the contact patch) to the top of the front tire. This is called your antisquat neutral line. Anything above this line means your AS is over 100%. Anything where the IC is below that line is obviously under 100% but also yields squatting.
Back to Yellowbullet I go.
-Mark
Old Feb 19, 2016 | 11:08 PM
  #131
Bitemark46's Avatar
SRA FTW!
-Mark
Old Feb 20, 2016 | 10:32 AM
  #132
HioSSilver's Avatar
-Mark
Nothing vanilla about it. You simply don't know do so you throw **** out like this and continue to believe sra is da best with out examining other options. There are varying degrees of anti-squat and anti-dive. It doesn't go from 0 then straight to 100%.....sorry bud it doesn't work like that.
And again....because you fail to understand all these forces are not forces until the turning of the tire creates them.
Have fun at yb.....stay there
Old Feb 20, 2016 | 10:46 AM
  #133
HioSSilver's Avatar
Failure to comprehend other forms of suspension (and the refusal to do so) does not make one smart......quite the opposite.
Old Feb 20, 2016 | 10:53 AM
  #134
NateLS1Mustang's Avatar
Bitemark with the kill shot.
Old Feb 20, 2016 | 11:23 AM
  #135
"MAC"'s Avatar
If irs is so much better why does doug have a sra?
Old Feb 20, 2016 | 01:27 PM
  #136
Nick.H's Avatar
Yeah dougs racecar is made with genuine ford parts like his rear end
Old Feb 20, 2016 | 03:35 PM
  #137
"MAC"'s Avatar
The faceplated trans that he has slows him down no BS he even said so himself
Old Feb 20, 2016 | 03:57 PM
  #138
Fresh got outclassed and outmanned fer sure
Old Feb 21, 2016 | 08:11 AM
  #139
HioSSilver's Avatar
It is clear to see who has the forsight and understanding for where improvements can be made and who does not.
Old Feb 21, 2016 | 08:13 AM
  #140
HioSSilver's Avatar
Lol....bitemark got outclassed and high tailed it back to yb. That's what you witnessed.
