16SS vs gt500
Yes. New tires = good thing.
And I said that the bolt on ls1 range from high 12's to high 13's. That's fact right? There are also alot of 11 sec ones there too, as I already stated.
My point is, and you should be able to back me on it then if you go as much as me. That the gt500's are letdowns for the most part. You get one out of it seems like every 5 that run well. Which I stand by my statement that for what the cars are, the m6 fbody's perform better than the gt500. I clearly stated that they don't have better et or trap, but for what they are, the ls1 on Ave performs better, period!
Edit: talking bone stock.
I also said that the new coyote on Ave performs better than their top of the line production gt500 and I stand by that statement too. All we have to do is actually sit and film a couple wide open Wednesdays and midnight Madness's to prove it Lol.
The GT500s at Gateway are a horrible example of their capability, I will give you that, but there are some guys who know how to drive getting respectable times out of them.
We can agree to disagree. When I go there, I always watch super closely for the 12 sec LS1s that aren't obviously cammed, and they're few and far between in M6 form. WSsick's was pretty bolted on and he ran a 12.5 @ 112 I believe, he drug my 95 Cobra's *** down the track
I'll start recording them though, because that means you're saying that the bolt on ls1 don't even run in the 13's since I said high 12's through high 13's. Out of curiosity, are you saying they run 14+ sec?
At least we agree on the gt500 though
Yeah, I guess we will Lol
Hard for me to explain it . But I'm sure you have noticed the rt tire spinning first or in a open diff be the only one that spins. That's because it's unloading. I just used the term spinning harder.
None of those cars had a dr on them either.
I've seen cammed ones run 13s.....no real excuse for that. That is all on the owner.
To be fair, I'd say only half of the vettes run good too. There's some really good running ones. Then there's the ones that still run good, but should do better for their mods. Then there's the ones that have horrible drivers/et's with a nice trap speed. Then you have the ones that you have to double check the return Lane on the way by that it really was a vette
All cars have good and bad, but some fall into the wtf category more than others
How did you make it through college with such low comprehension? I'm not the one that threw out the "fizziks" initially
No not the crank rotation. The rear end. If it wasn't bolted to the suspension it would just rotate in a sra car.
What makes you think the left tire is unloaded? Movement of the body.......cause you are off track if you think that.
I was going to point out that one tire would always be loaded more (due to inertia from crank/flywheel through the body), but you are right, IRS would definitely dampen that affect compared to a SRA setup.
I've seen plenty run like **** too. But it's not because of the car. A ls1 car should easily run bottom 12s these days and there is way mire than enough proof to show they can reach the 11s with enough ease. Mine ran 12.6 with very little done. Phills ws6 ran 12.9 with only free mods. Nathans 11.9 with out headers. Another friend went 12.9 bone stock. I've seen many run bottom 13s. I drove another to 13.0 with only a cut out/free mods.....on that run i put it in 4th gear....pulled it and put it back it just to be sure it was in. Woukda been a 12 sec pass no doubt but his shifter was stock and i didn't want to do the dreaded 3-2 shift so i was cautious.
For the most part around here, that's what the bolt ons unfortunately run. Tbh, the cammed ones don't run the times the fast list ones do. Maybe that's because of the driver, or they refuse to do weight reduction like me. Mine was as basic of a cookie cutter build that you could do, with zero free mods, but it worked ok for what it was. It could have ran much better than what it did and wasn't a good example of a proper cammed ls1. But even being an off the shelf TSP cam, full exhaust, ported TB, yank stall, still did quite well imo full weight. I listened to my builder at the time (too busy at work) and was happy I did. Could also be that mine was cammed with only 15,8xx on it so it wasn't ragged out.
That tells me that these cars do have alot of potential, that most people don't know, or care to learn about. I honestly think that it should be relatively easy for someone to take a cammed ls1 camaro and run high 10's. Weight reduction, suspension, free mods, on top the right combo/wheel setup, there's really no excuses not to.
Mine excuse was that I wanted zero weight reduction, I want my ac, and I want my car nice. That's the only reason I'm boosted now is because I wanted more power, and it's the lesser of two evils money wise.
As for the gt500 discussion, I was talking bone stock, or close to. Unless they are modded and have weight reduction, imo they don't impress me. I've seen them with good drivers here, but still wasn't impressed. But, I'm not impressed with my car now either, that's why I'm rebuilding it lol.
