Street Racing & Kill Stories Basic Technical Questions & Advice
Camaro vs E85 FBO lightened 2013 5.0
Old 07-10-2016, 08:32 PM
  #161
NateLS1Mustang's Avatar
Mac still lost
Old 07-10-2016, 08:48 PM
  #162
big hammer's Avatar
Originally Posted by "MAC"
My willingness to learn is just fine. I know exactly what synchros do for a manual transmission. All I'm getting at is you keep saying the same thing hio says but have no data to back it up. Hell you just out a lighter clutch in, couldn't drive the car most of the year bc of your harsh winters, then the rear end broke twice. So tell us exactly how many miles you driven with the lighter clutch. Or are you gonna dance around that yet again?
Exactly, I never said it wouldn't however hio is talking like that's what saved his synchros when in fact he has none lol.
So how do synchro's work mac? Why would a light clutch make a difference?
Old 07-10-2016, 09:08 PM
  #163
Poppacapp's Avatar
Do rockers in essence give a car a different cam?
Old 07-11-2016, 11:13 AM
  #164
"MAC"'s Avatar
Originally Posted by NateLS1Mustang
Mac still lost
Unlike you I know what I'm talking about you seem to follow the crowd to feel like you belong.
Again I'll gladly answer your questions once you answer mine. Until then keep dancing around it.
Jarred lmao
Old 07-11-2016, 12:37 PM
  #165
HioSSilver's Avatar
No....your dumbass just avoided the data till cory chimed in. You obviously have no ******* clue or you wouldn't butch about the faceplates. If a light clutch is easier on my fp then common motherfucking sense says it's easier on syncros to you stupid ****.
Old 07-11-2016, 12:39 PM
  #166
HioSSilver's Avatar
No....the cam stays identical......it's not like change the degrees of the cam.
Old 07-11-2016, 12:52 PM
  #167
99peweterls1's Avatar
Nooo, just increases the distance between the valve and the seat.
Old 07-11-2016, 05:15 PM
  #168
"MAC"'s Avatar
So you have 0 experience with a light weight clutch and synchro's? Thanks for admitting that. Good talk maybe next time you'll actually speak on something you have experience with rather than make assumptions
Old 07-11-2016, 05:29 PM
  #169
Coming from someone that can't even make a logical statement..
Old 07-12-2016, 01:08 AM
  #170
Poppacapp's Avatar
Does lift change?
Does this mean that the valveamajigit and the seat thingy being further apart altered the operation and specs of the camamjigit?
Old 07-12-2016, 05:15 AM
  #171
Does lift change?
Being the higher rocker ratio increases lift at every given part of the cam lobe during it's cycle..
I would have to say yes, yes it does.
Old 07-12-2016, 12:06 PM
  #172
HioSSilver's Avatar
Still don't change the cam....or the degree of the cam
You stupid ****......yes i do. My 5/6 gear are syncro'd. Nathans car had a light clutch and syncro's. That 2 to your 0.
Not a good talk with....you're to ****** stupid to understand anything.
Nate terrin up tech with kill shots
Does lift change?
Sure it changes lift.....but the cam is identical. Not quite as effective as degreeing your cams tho.
Old 07-12-2016, 02:08 PM
  #173
assasinator's Avatar
it does change the lift duration @ .050" lift. it unshrouds the valves more and increases the effective duration/area under teh cam lobe curve. the only thing it doesnt change is lobe seperation. hammer changed to an early cam and probably retarded it a few degrees also.
Old 07-12-2016, 02:32 PM
  #174
big hammer's Avatar
Rockers are a nice little bolt on. Cheap and easy.
Old 07-12-2016, 02:38 PM
  #175
marc97taws6's Avatar
Rockers are a nice little bolt oin. Cheap and easy.
Yeah, they are a nice little mod. Similar gains to E85 on a Br0
Old 07-12-2016, 02:43 PM
  #176
big hammer's Avatar
Yeah depending on who does the tuning for sure
Old 07-12-2016, 11:03 PM
  #177
HioSSilver's Avatar
But the cam stays the same.
Yea decent
Not at all....e85 gains more. Rockers may be worth 1/3 of e85. Maybe less. I gained 4hp with rockers. E85 is in the 12-20hp range.
Old 07-12-2016, 11:07 PM
  #178
big hammer's Avatar
I think sometimes people use dyno sheets from poor tuners for e85 gains
Old 07-12-2016, 11:36 PM
  #179
Nick.H's Avatar
Yea decent
cmon doug. you of all people should know peak HP doesn't tell the whole story
Old 07-12-2016, 11:57 PM
  #180
Poppacapp's Avatar
So with my E85... cancels out Phils rockers powah for powah... but his Long tubes got meh. His no cats got meh. I will probably delete my cats before we meet up anyway... it's next on the list. Our cars are fairly close right now with me on E85 and on my full street tire setup. His car runs good for sure.
Quick Reply: Camaro vs E85 FBO lightened 2013 5.0
