Bolt on Mach 1 destroys bolt on LS1 Z28
#423
I beat a few Mach 1's with a cat back/cai 96 M6 LT1 car. I also beat plenty of stock LS1's too back then. Anything can happen...a good driver goes a long way. This was back when all these cars were basically newer and lower mileage...big difference. I bet most the stock LS1's running around today probably need lifters, valve springs, and a good top end cleaning from lack of a catch can.
That being said the Mach 1 did run good and it was close to the LS1 up until 100mph or so then the LS pulls up top...bout the same as a good running LT1.
#426
7 Second Club
That is an *** whooping. Even if you add Hammer's number into that one.
Looks like the LS1/6 bolt on list is correct in not allowing rockers. Hiocrew loses...again.
#427
#429
I see the CoyoCrew is still astonishingly asshurt over simple modded LS1/6's.
What's next, are you going to tell me that rockers make the car extensively modded? "It's the same as a cam, bro!"
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
#431
7 Second Club
#433
7 Second Club
#436
