Street Racing & Kill Stories Basic Technical Questions & Advice
LBO 16 SS goes 11.0@123
Old 12-22-2016, 11:27 AM
  #781
Mike Morris's Avatar
Originally Posted by Pray
A couple pages in I post up a graph from a cam car. The MSD still lost but everywhere this time. That car needs to be gone though in all fairness. I think the cam was ground wrong or is a tooth off retarded.
Comp grind????
Old 12-22-2016, 01:26 PM
  #782
ajrothm's Avatar
Stock the heads don't seem so great. We will just have to see how they do on the bench. In the past it really hasn't been that the GM exhaust ports them selves were all that bad. The valve jobs and valve guides were huge hindrances. I am hoping it is the same with theses heads. I think it is the small cam with VVT and the big old head runner that is actually working here. But for a 305 runner the stock flow sucks.
I wouldn't say the IM's are all that bad once they are ported. I currently have both the pump gas bolt on C7 record (I built, ported, tuned, and drove the car. It belonged to a friend though) and the bolt on Camaro records with my ported IM. Maybe they haven't updated the CF C7 list but I had it last I checked. I am going to try to max effort my stock IM as soon as I get a breather to see if there is anything left there.
BTW, I love your Z. That is the exact color scheme I would go with.
Thanks for the comments and the info.
I didnt realize the LT head was measuring 305cc... I knew it was big but didnt know it was THAT big. I'm curious as what the CSA measures out to. As you mentioned, I wouldnt touch the intake port...all the power will be in the short turn/bowls/VJ..... I would do some serious work in the exhaust ports/throats though... 170 cfm @ .600" advertised is TERRIBLE... Thats worse then a 99' 241 head...LOL
I'm sub'd for your progress. I do follow your stuff on the 6G forum....(I have a 6G as well...), I can't wait to see what you come up with for a head program and stock cam or very mild cam.
To me it seems on paper, that the LT is a step back or two from an LS3 (and the LT4 a HUGE step back from the LS9), however you can not argue with reality and what the 6Gs and C7s are doing on the strip.... Hell we have bone stock C7 Z51 cars here locally running 11.60s@120 in good air.
All comes down to dont believe everything you read...
Old 12-22-2016, 05:52 PM
  #783
assasinator's Avatar
What kind of height and size are you thinking a properly done tunnel ram would end up being? Any way it would fit under a stock hood?
I'll do some calculations and get back.
Old 12-23-2016, 12:24 PM
  #784
Pray's Avatar
Originally Posted by Mike Morris
Comp grind????
​​​​​​​yes, Comp grind.
Old 12-23-2016, 12:29 PM
  #785
Pray's Avatar
​​​​​​​Thanks. Christmas and all this testing has broke my butt for now. As soon as I have some cash laying around I am going to grab a set of heads and get to work. Heads will probably come before headers. I can consider the heads an investment with a possibility of return. Headers are for personal gain. Lol.
Old 12-23-2016, 03:05 PM
  #786
Could be a bad cam....they are terrible.
Old 12-23-2016, 03:12 PM
  #787
RealQuick's Avatar
Lots of hate in here! Nice numbers for the 6g.
Just be happy you don't have a 5g 😄
Old 12-23-2016, 03:39 PM
  #788
Pray's Avatar
​​​​​​​Thats what we are thinking.
Old 12-23-2016, 07:04 PM
  #789
UltraZLS1's Avatar
Pray you need to tell Tim something is up with the website. I tried to order hp tuners with remote tune combo today from the efi tuning website and it won't let me. Don't want to miss out on the Christmas special. He could also be losing out on other sales.
It keeps telling me the order can't be shipped and I need to change my address. I've tried a couple times and double checked my info with no luck. Also sent him a PM with no reply.
Thanks
Old 12-23-2016, 07:08 PM
  #790
Pray's Avatar
Thanks
​​​​​​​I just shot him a text. Thanks for the heads up.
Old 12-23-2016, 07:12 PM
  #791
UltraZLS1's Avatar
Thanks bro
Old 12-23-2016, 07:15 PM
  #792
Pray's Avatar
Thanks bro
​​​​​​​No worries. He is checking on it. He has your PM.
Old 12-23-2016, 09:01 PM
  #793
A first order Helmholtz runner for a 370" motor with a torque peak of 4k is 37.95" from the valve head.
BUT. that is a rough number. I need the exact intake lobe duration @.001". I need the intake port dimensions,. When there is more info like you are providing a more accurate runner can be calculated.
That is longer than I expected. It is simply NOT unrealistic. If a person has a motor with what I consider to be a perfect design, he can easily fab an intake to take advantage of torque.
Old 12-23-2016, 09:04 PM
  #794
If I had a lt1 I would ignore aesthetics and give it what it wants. I would build plenum volume between one half and one engine displacement in size. Two throttle bodies. The closer to one engine displacement in size, the more refractory the plenum will be.
Less responsive. Less reflective of the waves
Old 12-23-2016, 09:16 PM
  #795
I want to also mention that taper starting at the port entrance will add a rpm component for upper rpm power. For example the perfect runner for a 5.4 4v cobra R engine is 14" long with a 7 degree taper. Long for torque, tapered for high rpm power
Old 12-23-2016, 10:18 PM
  #796
Man, prototype one , SD tune it and see. Nothing to lose. No injector bungs to worry about.
Old 12-24-2016, 12:30 AM
  #797
99peweterls1's Avatar
Geww, this thread is still thriving I see. Lol
Old 12-24-2016, 07:01 AM
  #798
Pray's Avatar
It has taken so many directions now it is like 10 threads rolled into one.
Old 12-24-2016, 07:03 AM
  #799
Pray's Avatar
The port opening of the head measure out to H 2.125" and W 1.580" at it's two widest points. So general cross section is 3.357". I would have to measure some points inside to get a better picture of the cross section.
Old 12-24-2016, 07:13 AM
  #800
Pray's Avatar
Here are my total gains so far. Run 1 is bone stock. Run 47 is right after my last fuel adjustment and no fuel trimming was added but we lost tach signal in a couple spots. AFR was pretty much perfect. Run 48 was the back up run but the trims kicked in and added fuel. Run 48 was about .4 richer on average IIRC. But I think this tells the story of why the car did a 1.577 60ft on the stock converter. Almost 450rwtq at 2,700 where the converter flashes.
Mods to date:
Pray ported IM/TB, Rotofab CAI, EFI Tuning E85 flex fuel kit, Pray/EFI Tuning Tune.
Next mods will be 3" dual cut outs pre AFM valves and 2" headers with cats.
Quick Reply: LBO 16 SS goes 11.0@123
