Epic SRK B/S thread of 2019
#4401
So when you keep saying the A10 is a power adder, you don't really mean it actually adds additional power, it simply efficiently exploits the available power from a small cube, high revving motor and keeping it in the higher meat of the power band "appears" via videos and track data that it adds power. I agree with this version.
You're correct, those dyno's do not favor a coyote, no doubt. Looks like a 427 LS is cheaper to get results per dollar than a coyote on a dyno . IIRC a coyote even blew up on the dyno.
Those dynos don't "favor" any one engine. The coyotah got thrashed in the na comparison to which was vs a 6.2. You can extrapolate the boosted power from that test if you want. Add 15 efficient psi to both. That will doube or nearly double the power. You will only find the gap got wider.
The invitation is open.
#4402
7 Second Club
#4403
Yes...the coyotah don't pull up for ****. It's really not a very powerful engine. Needs geared to death. That's why the a10 helps it so much vs the 6m car. Just like a power adder.
Those dynos don't "favor" any one engine. The coyotah got thrashed in the na comparison to which was vs a 6.2. You can extrapolate the boosted power from that test if you want. Add 15 efficient psi to both. That will doube or nearly double the power. You will only find the gap got wider..
#4404
Yeah.. Hio still mad at the 5.0 N/A beastly Coyote keeping up with a boosted ZL1 on that video.
‘Coyote is really not a powerful engine’ - Hio
Oh wait it came from the internet IT MUST BE TRUE because Hio said so lmao. EDIT
#4405
Junkyard 5.3 with an ebay turbo > all
The following users liked this post:
JayplaySS (11-21-2019)
#4406
In hopes you guys catch on, I'm going to edit your insults to each other to TRY and set a tone of mature insults only - if you see your remarks edited, I did it with good intentions.
If you disagree with my actions, feel free to consult an Admin for removal (of my duties - there is a term for it but no politics) of your moderator.
** Still didn't mention politics
#4408
7 Second Club
#4414
Saves your little fingers from typing all the lies and bullshit after erryone gets back home.
In both vids both engines are of stock displacement. What was your point?
It seems yours is slow enough you're to skeered to find out the troof about it.
Idk.....could be a 4.8 lol
well....don't act like a biscuit and you won't get call one. Very simple....it all revolves around you really.
I saved jay the trouble
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#4415
7 Second Club
#4418
7 Second Club
#4419
Here's the na one....again stock displacement for both.
https://www.enginelabs.com/engine-te...-dyno-results/
I'd hate to take it that fair for shake down passes.
#4420
7 Second Club
