Street Racing & Kill Stories Basic Technical Questions & Advice
Epic SRK B/S thread of 2019
Old 11-21-2019, 05:39 PM
  #4421
Moderator
JayplaySS's Avatar
Originally Posted by HioSSilver
Sxc posted the boosted one. Stock displacement for both.
Here's the na one....again stock displacement for both.
https://www.enginelabs.com/engine-te...-dyno-results/
I'd hate to take it that fair for shake down passes.
10 4 thank you I’ll dig into it later then insert my thoughts in trade for your curses (j/k)
Old 11-21-2019, 07:48 PM
  #4422
sxc Z28's Avatar
Originally Posted by islander033
It would just be cool to talk about cars that are owned by members every once in awhile.
PS. 2JZ>Mod Motor> LS
I might go to that with my slow car. Always a good time at these events even if the keyboard warriors are quiet church mice in person.
mice, hope you can make it
Originally Posted by JayplaySS
Just for the sake of this ever mentioned video, what was displacement for the coyote?
coyote wasn’t stock displacement and the ls was
Originally Posted by AnnivSS
Junkyard 5.3 with an ebay turbo > all
lol 5.3 pretty good I seen one go 7.6 in person with a turbio stock rod bolts too
coyotard had overbore pistons and ls was stock displacement. look at you giving them a break
Old 11-22-2019, 08:10 AM
  #4423
HioSSilver's Avatar
I figure they lost bad enough. No use in them anymore.
Old 11-22-2019, 08:29 AM
  #4424
Moderator
JayplaySS's Avatar
Originally Posted by noose
Adkins has gone 5.975 @ 243, with a 3.9 1/8th mile... A couple months back he went 3.75 in the 1/8th soooo 2020 its not looking to hot for the mod motor guys.
Yea, my mistake not fact checking that, I make mistakes -
The current mod motor record (factory head castings) is actually 5.80 @ 256 (+13 mph over LS)
** Says coyote block, interesting
Old 11-22-2019, 08:49 AM
  #4425
Mike Morris's Avatar
For the average street guy the new Coyote is tough to beat with boost. A used s550 auto with boost is a good buy and build on a budget. Sometimes it turns out cheaper than a heads cam Z06 C6 and terms of total money invested. Vette is the better car but we talking straight line speed. While a Camaro SS may match it it is tough to find a tuner and the fuel system is not cheap to do.
Wonder if they figured out the tick problem and if quality is ok with the 19s and 20 Mustang V8 auto.
Old 11-22-2019, 09:53 AM
  #4426
noose's Avatar
https://www.youtube.com/watch?v=cJroh6EhikU
Mihovetz in his 5.88 pass went a 3.91 in the 1/8th.
The new JZ record is 5.6's and his 1/8th mile is a 3.74 if that puts things into perspective about the LS. The LS went 5 mph faster then the JZ in the 1/8th too and the JZ traped 255 in the 1/4.
The trajectory of the LS's record should be in the 5.6's at around 260+ mph in the 1/4. Just based on the 1/8th mile.
That being said the LS IS technically faster then the mod motor/coyote. None of those guys has gone close to a 3.7 in the 1/8th.
Old 11-22-2019, 10:13 AM
  #4427
Moderator
JayplaySS's Avatar
So according to current actual results the LS holds a faster 1/8 and Coyote 1/4 -
I didn't see the displacement of the LS honestly - the video didn't show, any idea?
Old 11-22-2019, 10:24 AM
  #4428
noose's Avatar
Best way to put it, but you and i both know if the LS car makes a 1/4 mile hit its game over. He's doing it on a radial too.
Heres some info on it, says its 427CI
https://www.dragzine.com/news/dave-a...car-to-the-5s/
Old 11-22-2019, 10:27 AM
  #4429
HioSSilver's Avatar
Na is the real test of a engine.
Old 11-22-2019, 10:49 AM
  #4430
Moderator
JayplaySS's Avatar
Didn't you post his 1/4 time?
Old 11-22-2019, 10:52 AM
  #4431
Moderator
JayplaySS's Avatar
I personally appreciate a well sorted N/A motor
Old 11-22-2019, 10:57 AM
  #4432
Moderator
JayplaySS's Avatar
** Thank you for the link
Here is (maybe) the most recent 1/8 - 3.83 @ 202
If correct, both cars currently, the et 1/8 favors LS and trap speed in 1/8 still goes to coyote at 351 cubes. Very impressive -
Guess well do this all day, lol
Old 11-22-2019, 10:58 AM
  #4433
HpipeFlowmasterStang's Avatar
This is why you dont work for Ford or GM.
Or in your case the real test of an n/a engine is reducing weight in your already tin can of a car. ‘But nooooo I need to go faster i gotta cut more holes’ lmaoooo
Old 11-22-2019, 11:52 AM
  #4434
HioSSilver's Avatar
Na is the only way to compare the engines if you truly want the engines compared. Way to many other factors with any type of power adder. If the engine is breathing on its own then you know where the power comes from.
Then add 15 efficient psi to both......the gap will only grow in favor of ls/lt stuff.
https://www.youtube.com/watch?v=twGkJWEYZ78
So the furd is a maxxed out bored stroked piece while the ls is at stock ci......interesting. I'm sure the furd guys will whine about that discrepancy. Especially since it's not mod4mod
are you ******* stupid??? Serious question. I mean haven't you noticed all the efforts towards weight reduction these days you EDIT?? Seems as tho i was just a bit ahead of the curve. How bout you call up plane engineers and race car engineers and new car and truck engineers and tell them how reducing weight is stupid.
Old 11-22-2019, 12:53 PM
  #4435
noose's Avatar
Yeah the 1/4 passes are old, i believe thats when the car debuted. The car now competes in radial vs the world , they only run 1/8th mile. He's kicking *** in that class.
Regardless of the outcome even if LS is fastest or JZ or mod motor, the normal people (us) want to go fast on a budget and there's no other platform im aware of going 4's in the 1/8th with a SBE except the LS stuff.
A guy on here went 4.50s with a SBE LS a month back, thats 4 tenths faster then my built JZ car, i know how hard it is to get into the 4's in the 1/8th and to see a stock bottom end anything do that is damn impressive. Hats off to those guys.
haha don't doubt it these door car guys are killing it.
The following users liked this post:
JayplaySS (11-22-2019)
Old 11-22-2019, 07:58 PM
  #4436
7 Second Club
islander033's Avatar
....That being said the LS IS technically faster then the mod motor/coyote. None of those guys has gone close to a 3.7 in the 1/8th.
Lets research a bit before posting k?
This is the MMR coyote promod slip.
Ps. Here we are talking record cars again. Lol
Old 11-22-2019, 08:38 PM
  #4437
https://www.motortrend.com/news/c8-c...m=&utm_source=
Old 11-22-2019, 09:28 PM
  #4438
Moderator
JayplaySS's Avatar
I was at the shop busy as hell, so I didn’t have ample time, obviously
Damn
I love seeing these guys putting it all on the line!
Old 11-23-2019, 06:50 AM
  #4439
7 Second Club
Damn
No probs Jay, here are the LS stats. Similar in ET but down a lot in MPH vs the MMR car.
Makes the coyote faster and quicker than the LS....currently.
Old 11-23-2019, 07:02 AM
  #4440
BlkMach1's Avatar
How fast is the quickest 1/4 coyote now?
Quick Reply: Epic SRK B/S thread of 2019
