Street Racing & Kill Stories Basic Technical Questions & Advice
Epic SRK B/S thread of 2019
Old 10-03-2021, 10:50 AM
  #8301
HioSSilver's Avatar
Oh man that was bad. Good luck.
Old 10-03-2021, 11:56 AM
  #8302
spikestang's Avatar
Update, the car is now running on 7 cylinders, I'm thinking lifter, anything else it could be?
Old 10-03-2021, 04:37 PM
  #8303
S8ER95Z's Avatar
😞. Could be damage plug? Valve train damage? Are you getting flashing SES light or just can tell it’s running rough.
Old 10-04-2021, 03:07 AM
  #8304
JC316's Avatar
Lifter usually makes a hell of a racket, especially if it's fucked enough to kill a cylinder. Might just be a coil or plug picking a really bad time to die. That or you flattened a cam lobe..
Old 10-04-2021, 08:14 AM
  #8305
spikestang's Avatar
no noise, just a misfire, I will get a idle, revving video later today.
Old 10-04-2021, 10:05 AM
  #8306
NW-99SS's Avatar
Wish you the best spikey - hopefully not too much damage.
The following users liked this post:
spikestang (10-04-2021)
Old 10-04-2021, 01:01 PM
  #8307
JC316's Avatar
Check the oil for metal. If you don't see any, I would be looking at the ignition system.
Old 10-04-2021, 02:44 PM
  #8308
spikestang's Avatar
I changed it right after I got the new pump in, I strained it, and found nothing. I also cut the filter open and found nothing there either. It has 30 miles on this oil, I might drain it tonight, run it through a cloth and check for metal again.
Old 10-04-2021, 03:10 PM
  #8309
7 Second Club
islander033's Avatar
When you wreck an OPG, it's very rare to catch it before anything else gets damaged. Hope you got lucky spikestang!
The following 2 users liked this post by islander033:
S8ER95Z (10-09-2021), spikestang (10-04-2021)
Old 10-04-2021, 08:39 PM
  #8310
spikestang's Avatar
thanks guys, it's still not throwing a code, it just kinda snaps, and pops until around 26-2700 rpm, then it clears up. I think my car knows when I'm trying to save money for other things lol. I will get it to someone who knows more than me in a few days, part of me just wants to have it rebuilt.
Old 10-12-2021, 08:12 AM
  #8311
S8ER95Z's Avatar
sucks to be limping along like that. Any updates?
Old 10-12-2021, 10:44 AM
  #8312
spikestang's Avatar
nothing yet, I'm hoping this weekend. Everyone is super busy these days.
S8ER95Z (10-12-2021)
Old 10-12-2021, 12:01 PM
  #8313
Nick.H's Avatar
Hey Doug is your notch still for sale
Old 10-12-2021, 05:15 PM
  #8314
S8ER95Z's Avatar
all good, I walk past my Z28 several times a day and it’s still not up and about yet. Always hope other people can have better luck 😂
spikestang (10-12-2021)
Old 10-15-2021, 06:29 PM
  #8315
spikestang's Avatar
pushrods, valve Springs, and rocker arms are all good. Fuel pressure is 58 psi. I might post a running video on YouTube, and maybe you guys can hear something I can't.
S8ER95Z (10-25-2021)
Old 10-15-2021, 06:46 PM
  #8316
spikestang's Avatar
Old 10-15-2021, 06:51 PM
  #8317
spikestang's Avatar
I just took that video 5-10 minutes ago, when I get back in the car, I give it a little gas, and it tries to quit, if I would have stayed on the gas, it would have quit.
Old 10-15-2021, 10:05 PM
  #8318
JC316's Avatar
Man that is gnarly sounding, but it still feels more like electronic than mechanical failure to me. I had an LT1 trans am idle like that once, both of the oxygen sensors were shorted out, but it was pinging and misfiring bad enough that it destroyed the head gaskets.
Old 10-18-2021, 08:01 AM
  #8319
NW-99SS's Avatar
Have you pulled the plugs Spike?
I would be confirming spark and fuel at all cylinders, then pull valve covers and at least look at the springs and see if there is any visible damage. If not, then I would disconnect battery, ensure computer memory is cleared, and upload the tune again and see if there is any improvement.
I also noticed the dash lights going slightly dimmer when throttle was applied at idle. I would check charging system as well.
spikestang (10-19-2021)
Old 10-23-2021, 08:29 AM
  #8320
AnnivSS's Avatar
I need someone to talk me into finishing my Camaro rather than selling it and buying a super clean but high mileage local C5Z.
Quick Reply: Epic SRK B/S thread of 2019
