Epic SRK B/S thread of 2019
#8741
Not sure what that vid is about. But that et is much slower than a stock fatgen which is basically the same car as the holden.
I guess you like posting races where one of them misses a gear.....weird.
Yea they were gutless like the rest of the 4.6s.
just say you don't like the facts. The facts I said are facts. The facts do not care about your feelings.....or mine.
But I am smart enough to look at facts and not let them get in the way of my feelings....you're not.
The modulars got smoked on actual power which happens everyday in the real world. Remember there are zero 1000+ hp modulars. There are zero 650whp modulars in street cars. There may not be any 500whp modulars. A few coyotahs but none of them are doing it on pump gas.
The following users liked this post:
HioSSilver (08-04-2024)
#8745
If it's a similar build to mines it won't even be close......although I think it would be cool if it was. Mines way more basic than you think. I wasn't trying to set records with it.
I go back to the dyno on 8/16. Hopefully all goes well. This time with the new fuel pump and filter set up it shouldnt be leaning out at 6600ish. It needs to be ran out to about 7800. I was hoping to do flex fuel but I don't think that's a good option for these ecu's. Pump gas it is. Be nice to see it pick up a little more. 560whp maybe....hopefully.
#8746
For chody and the furd clown crew. That's why yall 4.6 didn't make 494....because this one makes 540whp and that one isn't nearly as good as this. And this has ALOT less drivetrain loss than yalls.
#8747
I haven't had to yet.
#8748
https://youtu.be/7K2HJM0pWi8?si=zojgtd19KfGdGZbM
The yellow 494 whp Mach with a little more compression and better fuel would make the same power.
#8749
By similar build I guess you mean that 4.6 was leaning out up top therefore not making all the power it could....odd I didn't hear them say that in the vid.
By similar build he's using a race 4speed vs a oe 6speed that will free up more power.
By similar build you meant the 4.6 has more compression and aftermarket rods and on a fuel.
By similar build you seen all the power accessories that engine is turning and the external oiling that usually doubles as a vac pump.
By similar build power going through the furd copy of a 12bolt vs a fab9. Likely with a lightened spool and hollow axles. Probably with lightened/polished gears freeing up as much as 10-15hp.
By similar you meant using a carburetor which typically makes more power.
All these are reasons why yalls 494whp 4.6 didn't actually make 494whp. Because that 540whp engine in that mach on pump gas may not make 494whp.
If the build was actually similar my 5.7 would make 600whp easily. Which actually plays out since my buddy built a 5.7 that made 680 crank with 243s for a dirt car.
#8750
It is a class racecar with lots of engine restrictions so there is plenty left for said 4.6. The car would make similar power with EFI
Show me one 346 making over 600 SAE on a Dynojet
So yes very similar to your car. It is just a little lighter and faster.
#8751
The 540whp 4.6 is very similar to your 10lb clutch and face plated trans combo that you have pulled every ounce of rotating mass from over the past 15 years so you can make the # you did.
Sooo.......600whp 5.7 is in a dirt car. You crazy mad because muh unfinished street car made more power than the race car 4.sux
Build a 4.sux like yall say. I'll be waiting for the excuses.
#8752
funny because I posted factual **** and all you came back with was rhetoric.....either that or henry furds nuts sack is in the way of you seeing things clearly.
Similar compressions, stock ported heads, cams (this class limits cam specs so probably smaller than yours) and an aftermarket intake manifold. You know just like your car lmao.
Take this 4.6 with no restrictions and put it in a slightly heavier street car. It will yield similar results and make you cry.
The only excuses will come from you. If my 4.6 makes lets say 20 more whp than your 346ci LS you will just scream fake numbers because you are just like every other Democrat.
#8753
Btw...lol at pulling every ounce of rotating mass in my car. I didn't know regular axles, regular gears, stock brakes and a truetrac weighed less than a likely a lightened gears,spool and hollow axles in a 8.8. Not to mention the drag brakes like on that car.
I didn't know my clutch weighed 10lbs.....i wish it did just to hear you cry more.
My car would likely pick up 15whp or more with that cars rear end set up.
Yes carbs make more power. Due to the cooling effect they have on the air.....but you knew that. Ooohhh wait you didn't.
So not similar to my car at all....it's a 2600lb with driver race car.
#8755
If leaning out is hurting power you will see a notable dip in power that correlates with the drift lean, does your showcase that?
More cope
On the RH corner of the engine is the alternator.
On the LH corner of the engine there is nothing
There is no external oil (or vacuum) pump on that engine, meaning it's wet sump oiling just like yours [presumably] is.
Mope coping
In their words, reduced reliability with no measurable performance gains.
More coping
You don't have any concept of MBT do you?
Had that same 680 crank had come from a Modular imagine all of the pearl clutching you'd be doing, just more confirmation bias from someone really out of his depth.
#8756
Here is a 2v in that class with the ballast pulled over 10 years ago thrashing 99% of NA LS cars lmao. Now imagine what a 4v would do at the same weight and another 100whp.
Brandon Alsept Has The World's Quickest And Fastest 2-Valve Modular - FordMuscle
#8757
A minor leaning out on the top end often gives an artificial power spike on the dyno.
T5 vs T56 losses are marginal, within statistical noise.
More cope
By what, a point or so you claim?
It's running a magnetic external crank trigger and a remote mounted oil filter on the driver side frame rail.
Mope coping
Having known many Factory stock, Coyote stock and Pure Street racers most of them do not run lightened/polished ring and pinion gears.
More coping
A Sullivan intake is utterly archaic compared to most modern EFI intake manifolds modeled using CFD.
Quite the logic you're using there, how much benefit do you think 13:1 is worth over 11.4:1 on 93 octane?
Sounds like an extremely happy engine dyno
More cope
Mope coping
More coping
T56 to t56 is very large. T56 to 3650 is large....We've done that . I bet you haven't. Now t56 to that racing 4speed is ginormous.
They all run lightened polished spools/gears/hollow axles. I've know a couple too.
Cool...Don'trun a sully intake then an yalls miracle build then. From what I've noticed once **** gets serious they're the way to go. Along with high rams or tunnel rams. But you can probably do it with a ow furd intake.....oohh wait you've done nothing yet except run dat mouf.
Since that 4.6 engine in the vid wasn't on pump it did fine on race gas. Just like yalls 494whp didn't make 494 at your claimed 11.25 compression. Which is now up to 11.4.
That 680 was real. He's built lots of ls, bmw and furds. So i assume that dyno would be happy for the furds too eehh.
Now come back when you have something to run besides dat stank breff mouf
The old N/A 4.6 4v pure street cars went low 10s at 132ish making mid upper 400s with class rules at 3400lbs. At a ~2900lb race weight and no rules like said "cam" only ls1 car they would go mid 9s at 140+.
Here is a 2v in that class with the ballast pulled over 10 years ago thrashing 99% of NA LS cars lmao. Now imaging what a 4v would do at the same weight and another 100whp.
That thing is slower than ALOT of h/c ls stuff. Including just a simple bolt on ls7 that went 9.0@15x.
Build a 2v then. Do something besides mouf about 2500lb race cars.
#8758
So we have concluded you 2 are just a couple furd nuthuggers that hasn't built anything na that can even keep up with bolt on ls/lt stuff.
Keep running those jaws tho. The more you talk the more erryone sees the less you've actually done.
#8759
Does your dyno graph exhibit an observable dip in power that correlates with the lean drift or not?
If the HP and torque curves carry along their natural curve and do not show an obvious dip in power that correlates with the AF lean drift then it is unlikely that the lean out actually hurt your numbers to any significant degree.
It could have even created some minor detonation that the dyno software smooths out to slightly inflated numbers.
So it's simple, does your graph indicate the lean out hurt your final numbers or not?
Do you even know?
Are you also implying you didn't rev your engine high enough to see peak power?
That's amazing
T56 to 3650 is "large"?
T56 to a T5 with OD deleted is "ginormous"?
I love this scientific terminology.
The fact is manual transmissions aren't using fluid pressure to apply clutches or couple converters and 4th is typically a direct drive gear.
There aren't "large" and "ginormous" drivetrain loss variances between typical light duty manual transmissions in isolation.
If you're finding "large" and "ginormous" (whatever that means) power variances from 1 manual transmission to the other you'll likely seeing it in clutch/flywheel/driveshaft variables more so than the transmission itself.
I've personally swapped and dyno'd all of these combinations in 4V Mustangs, including the TKO.
All examples were within statistical noise of each other
Just more coping
Rounding hard for you?
WTF are you talking about?
Your logic and arguments are trash, the only conclusion reached here is that you're a perpetual goal post mover with no intellectual honesty
#8760
Otherwise I call BS.
