Epic SRK B/S thread of 2019
#8882
#8883
You dumbass....it was a proprietary gm design. So what I said stands.
Since furd didn't even cast the teksdud block themselves I guess it's not a furd by your thinking.
548whp pump gas gm headed 5.7 is killing you furd guys.
Run along chump
Run along chump
#8884
#8885
Lingenfelter designed the CNC program, Lingenfelter did work.
So GM didn’t port the heads like you said, clown
#8886
So why didn't you answer my question???
The following 2 users liked this post by The Verz:
DualQuadDave (08-26-2024), HioSSilver (08-27-2024)
#8889
Always giving yourself a way out. Smart little hillbilly.
#8890
The following users liked this post:
#8892
Like i said.....by that mentality then the ultimate furd teksdud block isn't even furd. It was completely manufactured by another company.
Yalls hero fake 494hp is actually comparable.....except yall used a carb style intake. That style intake would likely make more power on this 5.7 also.
Don't act like my engine is max effort......it's far from it. Hell a actual replacement piston would have netted more compression even. But I played it safe with a set of returns from Amazon with 4cc valve reliefs to save some $$
My buddy built a 680hp crank 5.7 using 243s. And that was for a dirt car....so not even max effort there.
#8893
If it can't run on pump gas, or it has a cam so big that it can't pull enough vacuum to operate the HVAC system, or something that can't get rolling unless it has 5K RPM, it's not streetable.
#8896
Gm developed that part design for grand am cup.....thus it is a gm port design. The specs from the Lingenfelter heads to the gmpp heads are different.
why wouldn't YOU want it comparable? What does not being comparable prove???? Nothing.
The 494whp NA 4.6 wasn't a carb.
Well 680 is solid, about what a max effort NA 5.7 would make.
#8897
7 Second Club
#8898
I mean it will be a NA 4.6 on pump gas (Ported oem heads, drop in rod/piston, smaller lift and duration cam specs than your car). You need a max effort ls6 combo for that? Lmao 🤣
So now you gonna complain about lift...you can't run the lift ta pushrod style engine can. As far as duration, which is more important....
you're not gonna make *** much power with less duration. It's gonna take more.
Tell the class where your gonna find 80ftlb of tq at with a pissy *** 4.sux
Oohh that's right it had a super duper super rare fr500 intake.
some people claim if it has a tag it's a street car. One can drive a pretty fast race car on the street these days no doubt.....but that doesn't really make it a street car.
#8899
That wasn't max effort. It was a budget dirt car engine.
The 494 dyno that still has you crying had way less duration then your car lmao.
Why do I need 80ftlbs Doug? Average power wins races not TQ.
Yes it had a Ford intake manifold.
#8900
That 494 is fake af. Be lucky if it was 444.
Tq wins races. Tq is the only power. Hp is only a calculation. You can mutiply tq with gear.....you can't mutiply hp.
If a engine makes more tq.....then the equation for hp also increases. No engine makes hp....only tq comes out of the back of a crankshaft.
There may be a 346 out there that makes 600whp. That 680hp dirt car engine would make over 600whp.....jussayin.
There are no 500whp pump gas na modulars.....and worried about 600whp na ls. Hell you can't even get to my pump gas numbers by looking on furd sights with a modular 🤣🤣
