Street Racing & Kill Stories Basic Technical Questions & Advice
Epic SRK B/S thread of 2019
Old 09-09-2024, 08:36 PM
  #9121
HioSSilver's Avatar
Not really....my car just got done. Really it's not done it needs regeared now. Idk when that will happen or when I'll run it. As I stated before I'm just happy to be driving it.
Besides... I'm not bragging about what it did like you. I'm simply stating what the dyno said and you bitches are crying about it.
So post up what that junk ran.
Old 09-10-2024, 07:45 AM
  #9122
NA4VALVE's Avatar
So no track numbers to back it up... Got it.
Old 09-10-2024, 09:09 AM
  #9123
Mike Morris's Avatar
Hio local guy last week got one in before rain in his new Coyote. Last one went 10.19 but was lighter since it was a 22.
10.3 137
1 78 headers with cats. 3.0 Whipple. 315 gears. Carbon Fiber Ds. Rear seat delete. Heavy duty half shafts. Drag radials in drag pack. That is insane. Not even a real tune on it. Terrible air. Decent tune air that is a 9 second car. I don't see a 6 th gen SS doing that despite having a bigger motor. They are not boost friendly. Those Ford 4 valves love boost. Even the Gen 1 Coyote.
Older mods had weak bottom end shame. Even so 8 pounds of boost through to one they gained a ton.
Old 09-10-2024, 09:52 AM
  #9124
big hammer's Avatar
Originally Posted by NA4VALVE
So if Doug makes less power than a 4.6 does that make his 347CI LS "SUPER SLOW GARBAGE"? LOL
quite the butthole queef you just made there friendo
Old 09-10-2024, 10:00 AM
  #9125
LSux's Avatar
Tq is power is objectively right. Hp is only a calculation.
Objectively wrong again
HP is one of many measurements of power.
TQ is not power because torque can’t predict rate of work while that’s exactly what power does.
You keep harping on this “HP is only a calculation” because your backwoods inability to understand basic physics leads to you think that statement discredits the entire concept.
It doesn’t, it only highlights the reality that you straight up don’t understand the concepts you’re arguing about.
moron has a meaning too and you meet it
Idk what my 346 makes 8600.
Jack **** is what it makes
But if it was intended to turn 8600 it would make alot more than 300tq.
Is Sally had a dick she’d be Sal.
This is just a pump gas build that is basically sbe other than the pistons. And it's got yall turnt
It’s cam only Coyote power. 😂
You're not very smart for someone who took physics.......are you sure you dont mean physicals. Like **** physicals. Because it's definitely not numbers......or you would know my 346 isn't a 347. It's actually a 346.
only smart enough to discuss topics I actually understand, unlike yourself
also unlike yourself I’m smart enough to know that anything over a 346.5 is a 347 following standard rounding convention
Old 09-10-2024, 10:41 AM
  #9126
NA4VALVE's Avatar
You came back just to save lil ole hillbilly Doug. I commend you for that.
Old 09-10-2024, 02:20 PM
  #9127
The Verz's Avatar
C🤡dy or LSfuxmenightly couldn't build a NA car that leaves the 12s if their lives depended on it.
Old 09-10-2024, 03:29 PM
  #9128
HioSSilver's Avatar
no you don't.....but you're on here moufin like a bitch. So basically you were on that same happy *** dyno.
I will go run mine. It won't happen right away and I've said why. I still may but with the gearing like it is it's not optimal at all. It likely runs 60mph in first gear now.
So what did your junky ****** furd turd run again? You have 2 fake ****** dyno builds with no real results with lots of vlaims you can't back up.
Old 09-10-2024, 03:34 PM
  #9129
HioSSilver's Avatar
so I guess we can round my 548 up to 550 and since yalls junk turd only made fake 494 that gets called 490.......by your standards of course.
Or we can just call **** what it is.
Tq is power. You don't tq a bolt/nut in hp and you still get work done. Higher tq on that bolt/nut takes more power to tq it doesn't it.
Here's the problem.....you're ******* stupid.
Old 09-10-2024, 04:40 PM
  #9130
NA4VALVE's Avatar
I have backed up #s from that dyno. You obviously do not know how a DJ works or you do and like to fudge #s via weather station.
Old 09-10-2024, 05:11 PM
  #9131
big hammer's Avatar
wow praise from seizure
Old 09-10-2024, 05:16 PM
  #9132
HioSSilver's Avatar
post up what it ran then if you backed them up. Then we'll use one of the calcs your boi likes to see if it holds true.
I thought you claimed no way to cheat a dyno jet.....now your starry has changed. You just got busted af🤣🤣🤣
Run along boi
Old 09-10-2024, 09:40 PM
  #9133
NA4VALVE's Avatar
Run along boi
Made 790 SAE WHP (on a radial) @3700lbs. Went 144mph on a bias ply (would have went a little faster on a radial) lost about 40 whp with the bias ply on the dyno 756 with bias ply.
Radial- Your ET / MPH is 9.38 seconds and MPH of 144.02 MPH
computed from your vehicle weight of 3700 pounds and Flywheel HP of 885. (12% loss)
Bias ply- Your ET / MPH is 9.52 seconds and MPH of 141.93 MPH
computed from your vehicle weight of 3700 pounds and HP of 847.
So yes it was backed up. In fact I beat it.
Car also went 140 @ 3750 making 713 on a radial.
Your ET / MPH is 9.75 seconds and MPH of 138.57 MPH
computed from your vehicle weight of 3750 pounds and HP of 799 . (12%) loss
Doug I am willing to show my dyno graphs with the weather data. Are you?
Old 09-11-2024, 07:00 AM
  #9134
big hammer's Avatar
Chody just had another vaginal discharge irl
The following users liked this post:
HioSSilver (09-11-2024)
Old 09-11-2024, 07:08 AM
  #9135
NA4VALVE's Avatar
Poor Tyler. That the best you got? Did Jake hack your user name?
Old 09-11-2024, 07:13 AM
  #9136
big hammer's Avatar
Calm down my good fren and change your panties
Old 09-11-2024, 07:55 AM
  #9137
NA4VALVE's Avatar
Doug not given it up anymore? No more Hillbilly vag for ya?
Old 09-11-2024, 08:02 AM
  #9138
HioSSilver's Avatar
I'm not sure I even understand that mumbo jumbo.
Post up what your junk ran et/mph instead of calc'n it.
Dyno weather? It was hot and humid.....****** August dude.
Old 09-11-2024, 09:20 AM
  #9139
NA4VALVE's Avatar
You do not understand because you are not smart enough. Much like HPvsTQ debate.
Old 09-11-2024, 09:44 AM
  #9140
LSux's Avatar
Basic rounding is beyond your borderline retarded mental faculties I see
Power has a definition, I’ve given it to you repeatedly.
Your bolt analogy actually debunks you but you’re legitimately too stupid to understand why that is.
Let me help with what power actually is:
I know you can’t understand anything there, it just needs to be shared for posterity’s sake.
What does 440 lb-ft tell me about rate of work, dumbass?
”Torque is power” - WRONG
Quick Reply: Epic SRK B/S thread of 2019
