UMI Torque Arm
Thanks for the interest in our product
Our tunnel mounted torque and the Spohn tunnel mounted torque arm bolt in the exact same location and will perform the same. We have found ours to be a little more streetable since we use a polyurethane bushing set-up in the front while Spohn uses a solid bushing on the bottom.
How do you drive your vehicle? Does it see the street a lot? If so how much? How often is it drag raced? Is it ever autocrossed? Let me know and I would be glad to help.
Thank you!
Ryan
I would recommend item # 2205 seen here- www.umiperformance.com/2205 The Best V8 Stories One Small Block at Time
www.umiperformance.com/2200
www.umiperformance.com/2201
www.umiperformance.com/2202
www.umiperformance.com/2203
Thank you!
Ryan
I have however ripped it off the bottom of the Car, the factory mounts for that are very weak, and I'm re-enforcing them when I have the chance to get in there and do that.
I have the full length T/A with relocation kit, Poly/Rod LCA's and PHB. I seen you guys sell replacment poly ends. If i put those in place of the rod ends to make them both poly ends..would it make much of a difference??
I have the full length T/A with relocation kit, Poly/Rod LCA's and PHB. I seen you guys sell replacment poly ends. If i put those in place of the rod ends to make them both poly ends..would it make much of a difference??If I can help anymore please ask. Thank you!
Ryan
