ABSINOP Light Came On???Any Inforamtion.....
Re: ABSINOP Light Came On???Any Inforamtion.....
The only time I've seen that is on a road course and on a chassis dyno. It just went away after restarting the engine. ?? I don't know what to tell you.
I've had this happen to a few times. You may or
may not have the traction light on too and
the ASR may not turn on.
I spoke to Jeffy from SLP about it and basicaly
you should just drive it a few miles and more than
likely it will go out once the computer goes through
enough cycles and checks.
Once the system registers a problem it stays for a little
while. I ask if the traction light is on too because if
you saw this after braking hard the front tires spinning
slower than the rear sets that as well. I got both lights
once too after trying to get the car off the street in a
bad snow storm. If you spin the tires enough all types
of lights come on.
Also I started mine a bunch of time without the light
reseting, you have to take it for a drive and spin the
wheels
of lights come on.
wheels
wheels
I've had this happen couple times, I unplugged and cleaned the wheel speed sensor connectors 1 at a time until the light never came back on.
