Lowering springs
thanks
I don't believe in slamming the car. Here are some various links to pics of Strano springs on different cars:
https://ls1tech.com/forums/multimedi...hoot-well.html
http://https://ls1tech.com/forums/at...s-img_0955.jpg
https://ls1tech.com/forums/9341919-post7.html
https://ls1tech.com/forums/suspensio...ore-after.html
). Any lower than that and you aren't exactly lowering a little bit.Extra info.
If you don't put koni's on with any of the other setups, then I would tend to say the stock springs on the lower perch of the Koni's would handle best. Springs help out quite a bit but shocks do more than any single thing you will do to the cars suspension.
Do they work? Yes. Are they ideal being paired together? No, because the factory shocks aren't very good for factory springs. As you add time, miles, and the like they only get more sub-standard. Add stiffer lowering springs that want not less, but more damping control to give you a good result on the ride/handling side and it's not a great match for anyone who cares how the car actually works vs. just how it looks.
It's common for those that make or sell springs to tell you "they work fine". They can't really believe it, or their particular definition of fine is different than mine. Can you do it? Absolutely. Should you? Well, it's kind of like slapping a big cam in stock heads with stock valve springs. Will it work? Yes, but not nearly as well as it could or should.
You have the best shocks in place already. www.stranoparts.com --814-849-3450
