Best Stock F-Body Endurance & Road Course Brakes?
The starting point is OEM '00 Trans Am Brakes.
The first two upgrades are easy, SS Lines and DOT 4 or 5 Fluid.
As much as I would like to upgrade to a big brake kit, the class that I am running in limits me to running stock brakes…however, I can run any rotors/pads that I want. What is everyone's recommendation or consensus for good rotors/pads for Endurance & Road Course. During the event I will probably do 500+ miles and will have the opportunity to swap out rotors/pads (if necessary) at the mid-point. But, I need something that will have good grip and will LAST.
Suggestions?
Adam
Suggestions?
Adam
hawk HP+ or hawk blue 9012, brembo blanks for the front. HP+ rear, brembo blanks again. if its some kind of real race, get real race brake fluid. not just off the shelf DOT4/5. get ATE super blue/red.
read up at frrax.com for more indepth road racing discussions.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
You can purchase HP+ brakes at ws6store.com for a good price. I believe you can get brembo's at your local autostore, but I'm not 100% sure.
Yeah... I'm no expert but I hear the drilled/slotting are just hype and don't have any performance benefits other than cracking.
I would prefer plain so it will stand-out less in this class.... but will do CD or Slotted if there is a noticable benefit.
Suggestions?
Adam
Suggestions?
Adam
Or are you doing the 8 hour enduro in April at TWS?
![](https://images.ibsrv.net/ibsrv/res/src:www.ls1tech.com/get/forums/images/smilies/LS1Tech/secret.gif)
Edit: So, Chris Johnson smacked me in the back of the head and said I should give you a real answer. I am building a car for the 24 Hours of Lemons (www.24hoursoflemons.com).
Smack Chris back and then again for me.
Carbotech endurance pads are XP16s. They require a LOT of heat to work well. But, honestly, you might not even need to change pads ... rotors might be a different story.
If I were you, I'd call carbotech, tell them what your need is and they can even build you a custom thickness pad for this very occurence.
Chris said to just go with O'Reily or AutoZone cheapo blanks and that those "should" last.... or worst case, they don't cost much to swap out at the mid-point if they are shot. Do you concur?
i would think of entering the lemons, but i dont go for those dumbass penalties they have. beaters or not, im not letting some douche pour a pint of metal shavings in my crankcase as a 'penalty', or risk having a car i built and dragged all the way to the race be destroyed just by having my number pulled out of a hat.
I have a sale now, Powerstop Slotted rotors and i can get you the Extreme performance pads for $240. They should last you the whole race easy. And if you are really concerned about it, if you cryo treat the rotors any should last a 24 hour race. Don't know if they would last much more but they should do that for sure.
The topper was finding the specific car that I got... it is a car that both me and the 3 people on my team are intimately familiar with (between the 3 of us, we have owned 10 of them) and one of our team members is a tech at a pontiac dealer. So, our team has plenty of technical know-how on this chasis & drivetrain which might give us a slim advantage.
I figured we would give it a shot, I plan to come in right at budget so with the exception of the cage, I'm not out more than $500 either way. Hopefully the car will survive and we can tweak some things and race it again.
Speaking of cage.... any suggestions for a good, but cheap, cage in the Dallas area.... or elsewhere in Texas? I'll trailer the car to a different city if the deal is good.
Adam
