umi tunnel mount vs umi relocated torque arm
Stock 2002 SS suspension, Wheel spin seemed to be the problem, no wheel hop.
I posted two links below... please take a look and let me know if you have any questions and I will be glad to help.
www.umiperformance.com/2012
www.umiperformance.com/2015
Thank you!
Ryan
To start I would recommend a set of control arm relocation brackets and a good set of control arms. The control arm relocation brackets work as a ant-squat bracket and plant the rear end harder into the ground... they are a very inexpensive traction device and we recommend them. Also control arms help to eliminate deflection found in the stock bushings and flex in the stock control arms.
Thank you!
Ryan
Thank you!
Ryan
The relocation brackets may not work best for handling applications... but when trying to lower 60' times and increase they work great!
I was talking to the local performance shop about the tunnel mount torque arm and they were saying that since there is no real reeinforcement in the middle of the car, that with enough torque I will dent the floor board? Is there any truth to this? I was looking toward this one more than the full legth torque arm.
my understanding was that the tunnel mount ta was more so to be used with the 3-point subframe in order distribute the torque load through out the subframes instead of your floor
quick question guys i have ur tunnel mounted torque arm and it's an awesome piece. i've had it for about two years without any issues. i now ordered the pivot plates for adjusting my instant center and i had one question. what bolt size do i need use to hook the plates up?
#35
I just installed mine last weekend, I haven't noticed any extra noises. very nice install. Took about 3 hours to remove everything and we installed UMI Tunnel mount TA, upper lower panhard bars w/ relocation bracket. Also went with their driveshaft loop. My car feels like it is going to launch into space now. I feel sorry for my stock 10 bolt!! lol
#36
Good!
Glad you like the new set-up and I am sure you wont be disappointed in the performance either! If you have any other questions feel free to ask we will be more than glad to help.
Thanks Again,
Brad
adjustable, arm, bracket, camaro, ls1tech, mount, point, relocation, setting, torque, trans, transmission, tunnel, tunnelmount, umi
