17 or 18 inch wheels?
I have been searching for some time now maybe I just suck at searching but I can not find a ton of information on lowering a car with larger wheels. I am very interested in getting the Strano 1.2 lowering springs. I am looking at either 17 x 9.5 or 18 x 9.5 Y2K corvette wheels. I would really like to go with the 18's but before doing this I want to make sure this will all fit with, and what shocks would work the best for this. Just FYI i am brand new to all this stuff so don't kill me if its a dumb question.
Thanks!
If there is information on this just let me know the link!
Thanks!
18x9.5 will work with the Strano springs. I have 18x9.5 in the front and 18x10.5 in the rear and I will not have a problem when I put the Strano springs on my car. Just make sure that when you add the springs that you also add the afjustable panhard rod, to recenter the rear axle.
The only time the rears rub a little is under high cornering loads with my DOT-R tires. You will never generate these much of a load on the street with street tires, so they will not rub. You would have to roll the fender lip. They do fit much better on the front
So I have 315x35R17's on all four corners. The backspacing is 7 3/4 inch and I do run a 1/4 inch spacer on the front. No rubbing what-so-ever on the front.
I kept the stock springs in the rear with an 18 x 10.5 rim because with lowering springs the tires would rub if had someone in the back seat and hit a bump. So I ended up lowering the front and just throwing in some new stock height springs in the rear.
