Just Installed Subframe Connectors
I got UMI black bolt-in 2 point ones from Strano. They were great looking coming out of the box. Too bad they get bolted underneath my car. Putting them in was really simple. I didn't keep track of how long it took me though. Maybe an hour, hour and a half. Just follow the instructions and it goes smoothly.
They tuck up against the body really well. I was a little surprised actually. They are like a 1/4 in lower than the body seam, maybe less. I'm going to recheck the bolts in a couple days after driving it some more. I might get them welded up in the future.
I know most people say you feel a difference, you feel a difference. Well they're right. Pulling out of my driveway and through the gutter the car defiantly didn't rock and bend as much as it usually does. Driving down the street I rocked the steering wheel back and forth and sure enough, the car wasn't flexing like it use too. Turn in felt sharper and I can feel how crappy the stock shocks are.
This is my first suspension type mod. I'm looking forward to getting more stuff on my car. If you haven't done this already or have the parts and are holding off, don't. It's really simple and you will feel it.
Big thanks to Strano. Customer service was excellent like everyone says. I called up a couple weeks after ordering to see if they had shipped. All that got out of my mouth was my first name and what I ordered and he instantly told me they're on their way. Remembering who a customer is a big thumbs up as far as I'm concerned. Thanks again UMI for a great product and Strano for the customer service. I will be a repeat customer.
Ryan
Ryan
I had the same problem. My problem ended up being that the rear was not centered front/rear perfectly, so the tire on the passenger side had to be on the ground to get out, where the tire on the driver side had to be in the air. Try jacking it to different points and see where it comes out the easiest.
I installed bolt-in, boxed SFC's 5 or 6 years ago into my '02 Z28, and I'm very glad that I did. I immediately felt the difference they made, and to this day, the car is definitely still pretty "tight", considering the use and abuse I've put my car through .
What I felt in the car right away was that going over bumps and other un-even surfaces, etc., that the suspension gets put to work a little more, and the chassis doesn't "take the bump" instead. IMO, this isn't like doing a "free ram-air mod" and claiming ~5 HP on the butt dyno ... this is something REAL that truly makes a difference and is actually noticable.
I've never had the SFC's welded, but I've checked the bolts since, and they're still as tight as the day I installed them (which was f'n bloody tight! ).
They also provide a GREAT jacking point from each side of the car .
IMO, they're one of the few mods that would benefit EVERY F-Body out there ... whether you're into racing, or simply daily driving. For the small amount of weight they add to the car, they add so much structural support, I think it helps keep the car more solid for a much longer life.
Have fun running the corners with your new stiffer body!
Next on your list should be a Strut Tower Brace. Locking the front end up with the STB leads to much better steering response.
I've had them on for almost a month now. So I went back and double checked the bolts. Everything is cool. I have noticed less squeaks and rattles coming from the car since putting them on. Once again thanks UMI for a great product.
LS1TECH Sponsor
Ryan
Ryan
I have no idea how I missed this thread the first time around... Ooops.
Ryan, I appreicate the nice words. I talk to a lot of folks, and sometimes it can be overwhelming so I can't promise I'll always be able to remember every detail, but I do my best to remember people and their products. What every vendor wants is to have happy, and hopefully repeat, customers. I very happy to hear you felt I did a good job and deserve you as a repeat customer. Thank you.
As for the UMI parts. They are right up the road from me, not about 45 miles down I-80. I've always been 100% satisfied with the products Ryan and UMI have given me, as well as their willingness to work with me. On the very few occassions any sort of issue popped up it was always dealt with in a professional manner. The fact they are close, willing to work with me, and they make parts my customers also like is why I use their stuff when we need that sort of thing.
__________________
