suspension question...
Old Mar 13, 2009 | 10:25 AM
Nick_Rapitis's Avatar
Default suspension question...
when i go up steep driveways and that sort of thing my rear, mainly the passenger side, makes a sound like when an old door needs to be wd40'd...while im driving everything is fine even on big bumps and speed bumps...any suggestions?
Old Mar 13, 2009 | 10:39 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Just the chassis flexing or something binding. No worries.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 13, 2009 | 10:55 AM
didnt you post that sfc would help? i dont see it now
Old Mar 13, 2009 | 11:25 AM
BMR Sales2's Avatar
Depends on what it is, if its chassis flex then yes SFC would help. If its binding then you would need to either replace or grease the bushings that are causing the problem.
Thats why I took the SFC comment off, find out whats making the noise first then fix.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 13, 2009 | 03:18 PM
thats gonna be hard to figure out cuz i only hear it when im going into or out of a steep incline
Old Mar 13, 2009 | 03:51 PM
99Bluz28's Avatar
Stock suspension?
Old Mar 13, 2009 | 03:53 PM
in the rear yeah
Old Mar 13, 2009 | 04:04 PM
99Bluz28's Avatar
Try spraying some synthetic lube around the rear lower shock bushings, then the upper shock bushings and see if the does the trick!
Old Mar 13, 2009 | 04:23 PM
any kind in particular? i use that white lithium grease on my doors...is that the kind of stuff you're talking about?
