Suspension?
Old May 5, 2009 | 05:18 PM
PONTIACTRANSAM94's Avatar
Default Suspension?
I got eibach pro spring at my house and kyb agx shock and adj panhard bar. Is there any thing else i will need to go on or will that do it.
Old May 5, 2009 | 06:28 PM
Big_Bird_WS6's Avatar
maybe adjustable LCA.
Old May 5, 2009 | 08:04 PM
Do i need them or its something i can do later
Old May 5, 2009 | 10:29 PM
transamfreak01's Avatar
i did only lcas and pan hard bar and my wheel hop completely went away
Old May 6, 2009 | 07:35 AM
UMI Sales's Avatar
Thumbs up
I would recommend a set of lower control arm relocation brackets. These will gain back your traction performances that you loose when lowering a vehicle and eliminate any wheel hop that you may have. Below is a link to show you what we have to offer. If you have any other questions feel free to ask and I will be glad to help!
Thanks
http://umiperformance.com/products.php?category_id=125
Brad
Old May 6, 2009 | 09:22 AM
The lowering brackets keep you from having to buy lower control arms
Old May 6, 2009 | 09:36 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
You do not need adjustable lower control arms unless you have an aftermarket rearend with bad bracket placement or you are trying to fit a tall tire in the wheelwell. The relocation brackets help you get your lower control arm geometry back to the way it is supposed to be. The holes in our lower control arm brackets are drilled on an arc so you will not have to buy adjustable control arms. If you have any questions or need any help getting your car dialed in give us a call. Our tech dept is open till 6pm est mon-fri.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old May 6, 2009 | 09:44 AM
I still got stock wheels and that car came with 245/50-16. I still got the 245 on the front but running 255 on rear. So i shouldn't have to do either
