just inatslled BMR adj. torque arm!!!
I did it all in my garage and now my ride feels very weird...I hope I adjusted it correctly..should I take it to shop to have them do it or do you guys have any tips on an easy way to do it in your garage w/ no lift and only jack stands? Help please my ride sucks....it feels unsteardy kinda.thanks guys.
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Did you adjust the pinion angle according to our video:
http://www.bmrfabrication.com/
http://www.bmrtvonline.com/video_detail.php?mId=3788
If you have any questions, just give Lee a call here at the office. He's the best F-Body Tech guy in the suspension industry!!
yes I did but im not sure if the car was completely level..Does it have to be completely level for accurate readings?..I had the car all the way off the ground about 2 feet but not sure if it was level.
how do you load a suspension? btw, i bought a bmr k member and sould be coming any day does that have to be loaded too? i don't understand how to load a car if its off the ground
have jackstands under body of car, put level on door rails,, then jack up diff with jack almost to where it lifts car off rear jack stands. im no pro but i am a helicopter mech.
I have 4 race ramps I drive up on but this is basically what I do. Works well and you don't have to try jacking the rearend.
so what suspension parts are the ones required to be loaded when installed? lca's,phb,tq arm &tq arm relocation,etc? when i got install my bmr k member do i have to load the suspension after i installed the k member do i tighten everything down under load?bmr?
You will want to tighten down the front a-arms with the suspension under load also. I have seen customers tighten the a-arms down with the suspension at full droop and then have issues either with bushing failure or ride height being high or incorrect in the front.
