abs delete??????
Old May 14, 2009 | 01:28 PM
johnster's Avatar
Default abs delete??????
is there any way to delete the abs without buying the 250 dollar kit????
Old May 14, 2009 | 01:36 PM
WS6TransAm01's Avatar
CARTEK Racing
+1
Old May 14, 2009 | 01:46 PM
VTC_WS6's Avatar
Pull the fuse or disconnect the ABS modulator.
Old May 14, 2009 | 01:50 PM
Ericbigmac83's Avatar
if you don't use a proportioning valve or add a line lock you can make new lines yourself for pretty cheap
Old May 14, 2009 | 01:58 PM
johnster's Avatar
explain alittle more,,, got any pics? will the breaks work rite???
Old May 14, 2009 | 02:43 PM
The brakes will work ok, you'll just have a 50:50 brake bias which isn't ideal. All you need is a T to split the front line to the left and right side. then you need to just make new lines from the master cylinder to where the old brake lines connected to the ABS module.
Sounds simple. its not
Old May 14, 2009 | 03:58 PM
johnster's Avatar
thanks man ant other info???
Old May 14, 2009 | 09:21 PM
yea, call sjm and order the kit, lol
Old May 14, 2009 | 09:27 PM
waterbug1999's Avatar
You can get the LL and a wilwood proprtion valve and run/flare your own hose.. I bought the SJM kit and ended up redoing it.
This was a pic of my stand alone, but you can see the brake lines pretty good though.
Old Jan 11, 2011 | 10:27 AM
fastsspr's Avatar
I like more info. in this topic. I going to delete my abs looking for more space in the engine compartment and make the car ligther.
Old Jan 11, 2011 | 10:29 AM
FiredUpZ28's Avatar
Yea that 2 lb ABS block is weighin that sumb!tch DOWN!
Old Jan 11, 2011 | 11:33 AM
Asian LSX's Avatar
Anybody use the Burkhart ABS Delete block? Curious as to how that compares to the SJM.
Old Jan 12, 2011 | 02:56 PM
Big Al's Avatar
Will pulling the fuse kill ABS on a 95 Z-28? I'm planning a S-60 rear end swap and want to do away with the rear ABS sensor.
Al
02 Z-28
95 Z-28
73 Z-28
Old Jan 20, 2011 | 12:38 AM
fastsspr's Avatar
Were you can find that abs delete kit?
any link thanks.
Old Jan 20, 2011 | 04:13 AM
Duffster's Avatar
this has lasted in the internal section for how long?
Old Jan 20, 2011 | 12:16 PM
bjamick's Avatar
^ Ya I know.
Anyways you can just buy some 3/16 and 1/4 brake line from any parts store. These will be the new lines that go from the master cylinder. You will need to cut the factory brake lines and get the nuts off that screw into the master cylinder. Re-use them bc they are a bastard size on the new brake lines you bought.
The front supply from the master cylinder will go to the line lock, then out to a "T" then to the front calipers.
The rear supply from master cylinder will go to the wilwood proportion valve. Then the factory rear brake lines just screw into the prop valve.
All done. Just don't forget to double flare everything.
Old Jan 21, 2011 | 04:12 AM
jt76's Avatar
Weighs a lot more than 2lbs Plus opens up a lot of space in the engine bay.
Old Jan 21, 2011 | 07:53 AM
Pocket's Avatar
Can always use a 3rd gen prop valve. Its very compact vs the 4th gen ABS module. We've used LS1 F&R brakes with the stock 1Le prop valve for years
Old Jan 21, 2011 | 01:41 PM
ShevrolayZ28's Avatar
It's nice to have the block but a tee fitting can be used instead. IMO the best bet is to just get the SJM kit and be done with it. By the time you're done running around and collecting all the parts and tools to make the lines yourself, you've probably wasted enough time to make the SJM kit a better value. Just my two cents...
Old Jan 21, 2011 | 02:05 PM
Dirty Vegas's Avatar
Even with the SJM kit, you still have to flare your own lines.
