Braking Help
Old May 23, 2009 | 08:45 PM
JeaneZ28's Avatar
Default Braking Help
Everytime I let off the brake while driving my car it instantly jump 3 to 400 rpms. Any advice would be helpful because this is really annoying.
Old May 24, 2009 | 06:22 PM
JeaneZ28's Avatar
Anyone
Old May 30, 2009 | 11:38 AM
JeaneZ28's Avatar
Help..
Old May 30, 2009 | 10:16 PM
Wesmanw02's Avatar
Automatic??
Sounds like your throttle is sticking...
Old May 31, 2009 | 07:51 AM
JeaneZ28's Avatar
How is possible when the rpms go down as I'm braking.
Old May 31, 2009 | 09:53 AM
sroach20's Avatar
has anything been changed, tuned?
Old May 31, 2009 | 10:00 AM
99345hp's Avatar
Probably a vacuum leak in the brake booster.
Old May 31, 2009 | 10:42 AM
JeaneZ28's Avatar
I swapped my tranny out and since then its been doing it. The tranny sponsor dont have a clue what it could be but a vacuum leak. The hose i can see are plug in.
Old May 31, 2009 | 07:26 PM
99345hp's Avatar
what does that mean? even if all the hoses are plugged in it wont matter, the booster its self can be leaking.
Old May 31, 2009 | 09:25 PM
JeaneZ28's Avatar
It started when I put the new trans in. It wasnt doing it before.
Old Jun 1, 2009 | 02:33 AM
spy2520's Avatar
vacuum modulated transmission?
maybe its trying to do some odd shifting when you let off the brakes.
Old Jun 1, 2009 | 05:04 AM
JeaneZ28's Avatar
I dont think it has one its a stage 2 performabuilt.
Old Jun 1, 2009 | 06:36 PM
99345hp's Avatar
does it do it even if you are just sitting still with the car in park?
Old Jun 1, 2009 | 10:41 PM
JeaneZ28's Avatar
No its only doing it when I'm above about 20mph
Old Jun 3, 2009 | 06:04 PM
99345hp's Avatar
did you call the transmission company and ask them if there is a reason why? Could it be in the lockup of the torque converter?
Old Jun 3, 2009 | 11:47 PM
JeaneZ28's Avatar
I posted up in the trans section and the place I got it from didnt have a clue. The other vendors didnt know what it could be either. All they said was vacuum leak but it just happen right after the swap. I thought it might be the stall but I would like to know before I spend 8 or 900 dollars on a new one.
