Suspension most bang for the buck for launching.
What suspension are you guys running to get those 1.4 60ft times?
Just a basic recipe
Shocks
LCAs
whatever is sure to make a big difference.
Trying to hit the biggies that give the most bang for the buck.
I know tires play a big part as well.
Just list the things that you guys have found to work best. This will be for a c5 vette around 700hp on the gun. 408 stroker.
Thanks in advance.
Just a basic recipe
Shocks
LCAs
Thanks in advance.
Just a basic recipe
Shocks
LCAs
Thanks in advance.
Just a basic recipe
Shocks
LCAs
Thanks in advance.
I would suggest going with at set of lower control arm relocation brackets. And another suggestion would be looking into a adjustable torque arm and if you are making close to 450hp I would suggest getting it of the tail of the transmission and look into a relocation bracket. And just one more suggestion to keep the dimples off the quarter panels and eliminate chassis flex is a set of Sub Frame Connectors. Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/produc...ategory_id=125
http://www.umiperformance.com/produc...ategory_id=130
http://www.umiperformance.com/produc...ategory_id=131
http://www.umiperformance.com/produc...ategory_id=129
If you have any other questions feel free to ask and I will be glad to help!
Thanks Again
Brad
Not necessarily. This is LS1tech and the C5 was the first car to have an LS1 in it. I know... like 99.9% of the threads having to do with fbodies. I think the C5 guys just go elsewhere for info. Strano has setup C5's before though for handling applications.
Thanks for the replies. The best technical forum I have been on is this one. I use to have a 2000 SS that was pretty quick. Now I am in a C5 and its right here in this forum that my setup was put together. I ordered the heart for the project two days ago. I have 4 weeks before it ships. I am sure enough people that know are in here to help. Basically I just want to get my 60's down on 10.5 ET streets. Ill have well over 450FWHP. The motor is a forged 408 with a pretty decent sized cam. The car should see deep into the 700RWHP or better range with the 250 shot.
When building the SS there were things that I would definately say were more bang for the buck. Thats basically all I am looking for is what to start out with to reduce that 60. I am looking into a TA now and the SFCs really helped the SS transfer weight. The C5 suspension is a little different and I am brandNEWBIENEW on it so I could be going the wrong direction. Someone heare already verified getting a TA. Thats no problem I just want to know whats next that really makes a different over the stock suspension Springs, Shocks...
Thanks guys.
Thanks guys.
