Best handling setup
But in short... there are a few costly but very effective mods that these cars benefit from.
_______________________
2000 t/a ws6 with lots of mods
I would suggest a set of springs and a good set of shocks! Can't really help you with either of those.
But if you are going to be installing lowering springs I will be able to help you recenter the rear end. While suggesting a UMI Performance adjustable pan hard bar! And also a set of sway bars. Below is a link to show you what all we have to offer!http://umiperformance.com/products.php?category_id=124
http://umiperformance.com/products.php?category_id=161
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
The 17" wheels don't always appear very attractive, however I have found the 17x9 or 17x11 to function best when it comes to performance vs. comfort. Plus even with some tyres that have very stiff sidewalls, I have found them much more comfortable than 18's with a medium stiffness tyre sidewall.
^exactly
^strano performance
When you get shocks (Koni is probably your best bet, for a beginning; after RR for a while, you may want to step up to something better), get coilovers up front. I still have my Konis, but just put on stiffer springs.
Stick with stock control arms up front, until you get RR and know a lot more about this stuff. Offset bushings are good, though.
Adjustable PHR in the rear, along with weight jackers for ths springs. You can try a regular aftermarket torque arm like I did. But, I eventually had to get a de-coupled one. And, I still get brake hop.
Good brake pads and rotors. I use Carbotech XP 12 up front and AX6 in the rear. Baer 2-piece blank rotors. Wilwood 570 fluid.
Lay off the power mods until the car is suspended right, has brakes, and handles very well. Power should be the last mod.
When cutting weight, shoot to get under 3000 lbs. It's not too hard, but it makes a huge difference.
Thanks
Brad
