Koni/Strano Install Video
#45
Updated guys, Check out my mini video of the ride and review as promised!
http://videos.streetfire.net/video/K...and_689705.htm
#46
LS1TECH Sponsor
__________________
#50
Yeah, it took me forever to get my set up installed, just to many other things to do. Yea, I was on 395 but it intersects at I-80 just a mile from where I was at in the video. I would have taken the turns in the video faster, like where that round about thing was but its right where a construction zone is and there is dirt and gravel all over the roads. From the outside view when I pull a u-turn and take off, when I'm coming toward the camera you can here the sound of my tires sliding across the dirt as I try to stop. My wife was like, "why did you do the turn so slow?" I said, "Because if I went much faster I would have ended up in the sage brush behind you!"
#52
Ok so put the springs in the rear no prob and the DS was really easy too. Then came the pass side.
Everything went 2x as fast as the Driver side then BAM major problem. The 15mm nut at the top of the strut assembly was rusted to hell! WTF. Budged it with a 15mm deep socket but top of the shock started to move with the nut. So deep sock is no use now. Using a 15mm box wrench and clamps on top is getting me no where!!!
Please someone tell me what my options are now!?!?
#54
#56
