How do you lube Rod Ends?
i got superlube when i ordered my rod end PHB. its a little expensive for what it is, but youre buying from a manufacturer throus mail order, so what do you expect. i havent found it anywhere else, but im sure with some searching you can locally find some teflon spray lube.
If the Rod-ends are self lubricating, don't lube them!
That will usually accelerate the wear unless it's a dry lube, even then it could break down the lubricating material depend on what it is.
No oil or grease!
Most of the sponsors use self lubricating rod-ends on their products, unless stated otherwise.
No oil or grease!
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Helli
Thanks for the recommendation! We do offer the spray version it retail for $14.95 plus shipping and handling. And when lubricating the rod ends just spray the ends themselves on both sides if you can. If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
