suspension
Eibach V8 Prokit 98-02
Front
400lbs
Rear
80-137lbs
Drop
1.25
They aren't really stiff enough up front for racing, but they aren't a terrible spring for the street. The rear rates are the same..., there are worst springs with crappier rates out there. I'm not going to mention any brands....
If you have any RR or AX in your future look closely and research, if you just want it as a nice appearance mod then you should be fine, just remember the rates are only a slight improvement over stock. Which is not a bad thing for the street.
The drop isnt extreme 1.25", about the only thing I've seen here is the rear springs tends to sag, the rear will end up looking lower than the front.
Good luck.
only thing i would add to is are you changing shocks also? if you still have the factory decarbons this is another area of improvement to look into and would be great to do at the same time as the springs
