recommendations on new shocks and springs
Old 08-25-2009, 07:35 PM
nebur8's Avatar
Default recommendations on new shocks and springs
Ok, i have 124,000 miles on my z28. still have the stock shocks and springs. Recently spun a rod bearing and am currently having an lq9 installed. looking for a decent set of shock and springs for a small drop. This is my DD, no auto-x or drag racing done in the vehicle. I was thinking some of strano's bilsteins and his springs...any other recommendations?
Thanks!
Old 08-26-2009, 06:37 PM
nebur8's Avatar
so i guess i made a good choice?
Old 08-26-2009, 07:48 PM
ThoR294's Avatar
ya... haha
Old 08-26-2009, 08:22 PM
transwiz's Avatar
You could get a set of koni sa shocks and use the lower perch setting for a 3/4" drop in the front and the heater hose mod for the rear (1/2" drop)with the stock springs.Strano springs are really good if you want to lower your car app.1.2".The bilsteins are good as long as you don't ride in another car like yours with koni's.Koni shocks are adjustable are way better shocks than bilsteins.Call up sam strano and see what he has to say.I went with the lower perch/heater hose mod on the koni's.Like I said call up Strano and see what he reccommends for your application.Strano performance 1-800-729-1831
_____________________
2000 t/a ws6 with lots of mods
Old 08-26-2009, 08:26 PM
SpinsB's Avatar
Originally Posted by transwiz
You could get a set of koni sa shocks and use the lower perch setting for a 3/4" drop in the front and the heater hose mod for the rear (1/2" drop).Strano springs are really good
You are running strano springs with koni's on lower perch?? any issues wit the shocks??
Old 08-26-2009, 08:50 PM
transwiz's Avatar
I am running stock springs with the koni sa lower perch/heater hose mod.You can only use the lower perch with the stock springs.You have to use the upper perch with the strano lowering springs.
______________________
Old 08-26-2009, 08:53 PM
SpinsB's Avatar
yea I know thats what sucks. Im looking for a little bit lower in the front.
Old 08-27-2009, 06:08 AM
pjb
pjb's Avatar
transwiz - do you have pictures of your ride height? I'm trying to decide if I want to go back to my 98 SS springs with my koni's, or keep my DMS springs. I love the stance with the DMS springs, but comfy ride would be nice. Not that the DMS are terrible by any means.
Old 08-27-2009, 08:28 AM
Pontiacerator
RevGTO's Avatar
I am running this setup but with old-spec Bilsteins in the rear. 3/4" drop all around. My car wasn't super 4x4 to begin with so it worked out perfect. Pics in My Garage.
Old 08-27-2009, 08:40 AM
pjb
pjb's Avatar
are all those pix with stock springs and just the lower perch/hose mod?
looks good.
hows the ride?
hows the handling?
Old 08-28-2009, 12:10 AM
transwiz's Avatar
I don't have any picks of my t/a.My car was a little on the high side before I went to the koni lower perch/heater hose mod.I kept my stock springs because I wanted my car to ride fairly smooth.It makes the car look like it should if it was stock.My friend has strano springs /koni's on the same t/a (2000)and I love the way it looks.(1.2" drop)I thought the ride quality was a little harsh for my tastes.We live in Southern California and the roads are **** out here.Stock springs will ride better,lowering springs are a little stiffer.I prefer the smoother ride.
Old 08-29-2009, 10:15 PM
Pontiacerator
RevGTO's Avatar
Originally Posted by pjb
are all those pix with stock springs and just the lower perch/hose mod? looks good.
hows the ride? hows the handling?
Yep. Just the lower perch and hose mod on stock springs. Handling is certainly improved from stock shocks and there is less body roll just from being lowered that small amount. But sway bars are needed for a real handling improvement. Ride is good. My only complaint is that the Konis hit sharp bumps more harshly than the Bilsteins I had on the front previously. Other than that, the ride is excellent.
Quick Reply: recommendations on new shocks and springs
