What do I need??
koni sa shocks
UMI on-car adjustable PHB poly/rod ends
UMI bolt-on relocation brackets
All from Sam Strano (sponsor here)
I have all the above, except I have DMS springs that I got before Sam came out with his springs. DMS are no longer available, and I tend to believe Sam's are better anyway.
You won't be disappointed.
If you want less drop - search Koni lower perch and hose mod with stock springs.
Hello, this is actually a great time to be looking for the parts that you need. Our lowering springs drop the car 1.25", the fronts have a spring rate of 550lbs, the rears 160lbs. Our springs also have alifetime guarantee against spring sag. We currently have the springs on sale for $159 for all four if you buy $100 worth of any BMR product. Our adjustable panhard bar is on car adjustable and is available in a poly/poly combo or a poly/rod end version. The poly /poly version is $114.95 the poly/rod bar is $14 more. We also have bolt on control arm relocation brackets that do not alter your wheelbase and do not change your pinion angle.
As far as shocks go we have the Tokico HP series. They are a non adjustable shock that work very well with our springs. The Tokico's have increased dampning at at medium and high piston speeds. This results in very good handling and ride quality. Our parts ar ein stock and ready to ship. If you have any questions or would like to place an order please give me a call.
koni sa shocks
Thanks for recommending UMI Performance! We do offer a wide variety of aftermarket suspension parts that are made right here at our own facility. Below are the links to show the products that are mentioned above.
http://www.umiperformance.com/catalo...l4n67d4eu0e9j1
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
