rack and pinion question
but not crazy hard and heard a wierd noise. so i pulled over and checked the power steering pump level. It was over half empty. so i went home filled it up and looked under the front it was almost to the point of dripping. i took it to the dealership and they told me it needed a new rack and pinion and was going to cost 1200 for parts and labor and 800 for the part alone. i think thats outrageous. so i need your opinion on what to do ACDELCO Part # 3616562 if your car was delivered w/o Z-rated tires (F41 suspension)
ACDELCO Part # 3616537 if your was delivered with Z-rated tires (FE2, Fe4 or FE7 suspension)
Don't opt for the cheaper Cardone unit.
No new ones ... reman only.
Either ACDelco will cost you about $250 plus core.
That does not include OUTER tie rod ends.
Not a hard job, just really messy. Two bolts through the K-Member, two lines on the rack and remove the tie rods from the knuckles.
You'll have to have a front end alignment (toe) when done.
i'm guessing you have to look at the sticker to figure it out since the car is many years old.
is the sticker the one on the door?
Aren't the build codes on the inside of the glove box door? It's been a while since I had a car with all the interior in place. LOL
The angle on the replacement rack (wrong suspension option) made the steering column rub on the exhaust manifolds. Tech: "I had to do some tweaking to get the new rack in?" Some tweaking, they pounded on the exhaust manifold so much that they knocked the packing loose in the cat...
Make sure you order the right one.....
as I have not had the plasure of replacing one I am not sure but I think you will need to rase the moter in order to remove one of the rack mounting bolts OR just cut it out with a grinder or saz-saz and replace the bolt with a new one placing it UPside down and using a good locking nut
Johnny
http://forum.camarov6.com/showthread.php?t=94306
I'm still not clear, what else is needed to go from the 16.9:1 in the V6, to the v8 14.4:1?
