Need some good alignment specs....
Old Dec 19, 2003 | 06:47 PM
Damian's Avatar
LSX Mechanic
Default Need some good alignment specs....
Looking for something that won't chew the tires up, but offer the best handling overall. I'll probably road race the car a little next year, but not to much....Throwing some Bilstein HD's on next week and my alignment is trashed from 3 spring swaps....
Old Dec 19, 2003 | 07:43 PM
mitchntx's Avatar
Assuming stock suspension, except for springs ...
As much neagtive camber as you can muster. Probaly -0.7 or -0.8 degrees.
As much positive caster as you can muster. Probably something just over 4*
Zero toe will make the car walk in the road ruts. 1/16" toe in will help solve that, but will cost you in turn in responsiveness.
Old Dec 19, 2003 | 07:45 PM
Gev's Avatar
Gev
Trackbird's setup is nice. He gets about 30k on his tires. I'm sure he'll be in here momentarily to answer your question.
Old Dec 19, 2003 | 08:08 PM
emarkay's Avatar
GM Specs - Page 3-10 of 2000 manual
Caster: 4.5 to 5.5
Front Cross Caster: -0.7 to 0.7
Front Camber: -0.1 to 0.9
Front Cross Camber: -0.7 to 0.7
Front Individual Toe: -0.1 to 0.1
Front Total Toe: -0.2 to 0.2
Steering Wheel Angle: -3.5 to 3.5
Rear Camber: -0.6 to 0.6
Rear Cross Camber: -0.6 to 0.6
Rear Total Toe: -0.3 to 0.3
Rear Thrust Angle: -0.15 to 0.15
Note that these are GM "minimum common denominator" specs and some may have more prescise or different specs for specific applications.
Old Dec 20, 2003 | 10:59 AM
trackbird's Avatar
Sorry I'm late....
I am running:
-1.3 camber
4.5 castor
1/32nd inch toe out (yes, out)
I just changed my tires at 30,000 miles and the fronts were not to the wear bars (I'll send pics of the tires if you'd like, just tell me where to send them). I never rotate my tires though, I prefer to have "good rubber" on the front. That way the brakes always work in the rain. The right rear was about to the wear bars, the left was mostly gone (torsen) and the fronts were "decent". I suspect they would have gone another 8,000 before they really needed to go. I had about 25,000 of that wear on my alignment settings (listed above) and I drive it to work every day.
Hope that helps.
Old Dec 20, 2003 | 09:43 PM
roy's Avatar
roy
Track bird what type of tire are u running?
Old Dec 22, 2003 | 03:18 PM
trackbird's Avatar
Eagle RSA (Really Slide Around....or Really Suck A**). Factory rubber. Hated to toss it until it was dead or nearly so. I just bought a cheap set of ZR rated Sumitomo all seasons for the winter (then looking to go to 17" wheels). And, I wound up with snow tires (think "blizzack").
Old Dec 22, 2003 | 04:04 PM
mitchntx's Avatar
I can't even imagine what it's like driving a 4th gen in the snow.
It has to be "special" ...
I got 30K out of GSCs. All street miles and MAYBE a couple of AXs, but almost all street miles.
Old Dec 22, 2003 | 04:22 PM
trackbird's Avatar
Wimps....
It beats my 3rd gen on bald Eagle VR 50's and an open diff.....
Actually, if a torsen is good for nothing else, they work great in snow. Maybe the almost perfect snow diff....(I got stuck one time last year on a 1/2 worn set of RSA's).
Besides, it is great practice for autocrossing. Learning to work at the limit of adhesion. And that limit is real low.... Think of it as a poor mans track day.
Hey Mitch...when did you guys last see snow?
Old Dec 22, 2003 | 10:46 PM
mitchntx's Avatar
Last year ... we went to Colorado for a week ...
It was sunny and 73 here today ... Cold snap tomorrow ... high of 55, but warming back into the 60s by the weekend.
Looks like I might go to the race track this weekend to help a relatively new WC team do some shake down runs.
Know of any DECENT crew chiefs?
Old Dec 23, 2003 | 10:34 AM
trackbird's Avatar
I'm not a crew chief, but I play one on the internet. Ok...and I crew chief for an american iron team when I have time (www.darkhorseracing.net).
You did say 60 degrees, didn't you?
Hmmm......guess I could say hi to K9Kev on the way by....
Now....if I only knew something about cars.....
Old Dec 23, 2003 | 11:33 AM
mitchntx's Avatar
AI? I could have sworn you told me World Challenge ... my bad ...
Old Dec 23, 2003 | 03:08 PM
trackbird's Avatar
There's always time to learn....World Challenge, Go Karts, whatever, if it has a motor, I'll try to tune it.
Old Dec 23, 2003 | 04:41 PM
Bruce02Hawk's Avatar
Question
Sorry I'm late....
I am running:
-1.3 camber
4.5 castor
Hope that helps.
trackbird,
would you recommend those same specs on just a street driven car? I just had hypercoils and slp bilsteins put on my firehawk and i need an allignment. I've got the stock 32mm front and 19mm rear sways, slp subframes, stb, hotchkis lca's and a reinforced panhard. any help is greatly appreciated...thanks and happy holidays!!
Old Dec 23, 2003 | 05:26 PM
Damian's Avatar
LSX Mechanic
Originally Posted by Bruce02Hawk
trackbird,
I am wondering the same thing. I drive mine almost everyday....Trackbird?
Old Dec 23, 2003 | 06:42 PM
mitchntx's Avatar
You'll never get -1.3* camber without help.
Old Dec 24, 2003 | 01:59 PM
trackbird's Avatar
I'll put it this way....
Right now, I own one car (rare for me)and I'm driving it every day. The Camaro is my driver. I made a 375 mile road trip in it last night on snow rubber through the mountains (driving on snow tires is like running around on 4 flat tires...no feedback). I use those specs on a car that is an absolute daily driver. I've had my car for 19 months and have almost 34,000 miles on it now (I bought it as a new 2002). So, I feel qualified to say that they work just fine (rain, snow and all) on a daily driver. Besides, you'll never look at an exit ramp the same way again.
Kevin
Old Dec 24, 2003 | 02:09 PM
trackbird's Avatar
Most everyone here knows me and my setup. But for anyone who is wondering....
H&R stage 2 springs (647 in bl front, 258 in lb rear)
Koni DA's on both ends
SLP weld in SFC's
BMR (cringe) STB
Trackbird Engineering Aluminum Heim/Heim LCA's and PHB
And the alignment listed above.
Old Dec 26, 2003 | 03:08 PM
trackbird's Avatar
One last thing.
Yesterday, I drove 75 miles on snow (nobody had scraped the roads) with no problems at all (it tracks straight and is no trouble to drive). So, I'd guess that qualifies it as a street worthy alignment...
I was the only car that wasn't in the median. Actually, all the SUV drivers were finding out that 4wd works for going, but they still don't stop or turn on ice....oops.
