RPO codes is this supesion set up good/ rare?
6ZR COMPONENT FRT LH COMPUTER SEL SUSP (6ZR) SUSP(6ZR)
7ZR COMPONENT FRT RH COMPUTER SEL SUSP (7ZR) SUSP(7ZR)
8HS COMPONENT RR LH COMPUTER SEL SUSP (8HS) SUSP(8HS)
9HS COMPONENT RR RH COMPUTER SEL SUSP (9HS) SUSP(9HS)
FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4)
I just looked up my rpo codes just wanting to know if this susp set up is any good or what?
i did a google search and came up with this post from camaroz28 archives:
1998-2002 Camaro SS and WS6 Trans-Am/Formula came with FE4 suspension. The kicker is 1998-early 2000 models differ greatly from the late 2000-2002 models.
For 1998-early 2000 FE4 it included 1LE springs front and rear, the 1993-1995 1LE deCarbon shocks (1LE rear shocks are the same diameter as the front shocks and are slightly stiffer, I have not figured out if the fronts really differ from regular deCarbons), 1LE rear lower control arms, 1LE pan hard bar, 1LE 32mm front sway-bar and 17x9 wheels with 275/40-17 tires. I am not sure if any of the front suspension received any other 1LE parts other than the front sway bar.
For late 2000-2002 the only differences between FE2 and FE4 are very minor. The only difference is the 1LE 32mm front sway bar and the 17x9 wheels with 275/40-17 tires. Also of note is the fact that GM stiffened up the deCarbons for a firmer ride in 2001 untill the end of production in 2002.
I have been researching this for quite some time. I currently have 02 deCarbon front shocks with 1LE springs (from a 96 WS6 T/A) and stock 02 shocks and springs in the rear of my 2002 Camaro SS. It's amazing how much better the car handles with just the front springs installed. Less roll and the ride is only slight amount stiffer. Hope this helps clear some of the confusion.
still confusing, but it sounds like you have the stock upgraded suspension, IF the components are all stock anyway. its nothing special, as any quality aftermarket shock/spring combo will be better then stock anyway.
yeah this helps alot. i bought my car used it was already lowered so the springs are different anyways but the rest looks stock. Didn't know if it might be rare or what casue on compnine.com it says that the was only 2,547 camaros with this suspension set up
well i did a vin look up and these where all on here and everything else on the vin was right i just didnt know if this is what they all came with. because it said only like 2100 cars had the top 4 rpo codes on here
LS1TECH Sponsor
FE4 is the RPO, the other numbers are individual spring codes.....
__________________
RPO Description Matches Compare
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
35,858
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
49,339
UL0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,AUTO TONE(UL0)
12,893
UZ7 SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER 8 SPKR SYS(UZ7)
39,105
U73 ANTENNA,FIXED FIXED ANT(U73)
46,653
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
37,593
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
38,311
V12 COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)
2,721
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
45,496
WU8 SALES PACKAGE CAMARO SS APPEARANCE AND PERFORMANCE CAMARO SS APPEARANCE & PERFORMANCE PKG(WU8)
2,511
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
17,570
1AZ Unk. 5,160
1SG PACKAGE OPTION 07 OPTION PACKAGE 07 OPTION PACKAGE 07 (1SG)
14,603
1SZ PACKAGE OPTION- (1SZ)
44,603
13Q MOLDING COLOR,SILVER METALLIC (13Q)
5,731
13U EXTERIOR COLOR,PRIMARY (13U)
7,039
14B TRIM COMBINATION - CLOTH, GRAY (14B)
27,358
14I INTERIOR TRIM LT GRAY (14I)
38,393
2,606
2,606
2,547
2,547
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
27,607
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE PASS SI INFL RST SYS(AK5)
RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
49,339
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
48,391
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
35,858
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
44,872
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
37,947
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
43,762
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
40,487
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
39,572
CAE Unk. 2,511
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
38,784
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
49,339
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
35,156
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
44,619
2,507
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
42,328
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
13,815
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
24,022
IPB TRIM,INTERIOR DESIGN (IPB)
34,310
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
49,339
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
44,728
K68 GENERATOR,105 AMPERE 105 AMP(K68)
41,896
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
17,821
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
36,306
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
36,301
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
42,328
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
36,790
NW9 TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
8,034
N73 WHEEL,CUSTOM SPORT MAGNESIUM WHL(N73)(EXPORT)
WHEEL,CUSTOM SPORT PAINTED AL WHL(N73)
2,511
PBT Unk. 2,496
QFK TIRE ALL P275/40ZR17 93W BW R/PE ST TL HW4 TIRE(QFK)
2,511
R7A Unk. 44,603
R9Z Unk. 5,056
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
49,334
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
46,653
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
43,66
35,858
49,339
12,893
39,105
46,653
37,593
38,311
2,721
45,496
2,511
17,570
1AZ Unk. 5,160
14,603
44,603
5,731
7,039
27,358
38,393
2,606
2,606
2,547
2,547
27,607
49,339
48,391
35,858
44,872
37,947
43,762
40,487
39,572
CAE Unk. 2,511
38,784
49,339
35,156
44,619
2,507
42,328
13,815
24,022
34,310
49,339
44,728
41,896
17,821
36,306
36,301
42,328
36,790
8,034
2,511
PBT Unk. 2,496
2,511
R7A Unk. 44,603
R9Z Unk. 5,056
49,334
46,653
43,66
