Wheel hop HELL! HELP!
I have my stock 10 bolt with 4.10 gears, BMR LCA, 21mm rear sway bar, Panhard bar is on the way. I have my stock 17inch wheels on my car with Dunlop all seaon tires. My car in NOT lowered.
I am scared to touch my gas pedal in first gear... It is horrible. I can not believe my stock 10-bolt is still alive after some of the wheel hop I have experienced.... I really want to get this resolved. What else can I try?
Do LCA relocation brackets make any sense for a stock height car?
Tommy
Heres a check on the LCA's when the car is sitting on the grond from front of car ro rear of car do they point downwards or are they level? If they are level than Relocations will help.
Thanks for the advice guys. I can't wait to actually be able to hit my gas again in a low gear!
Tommy
I can't wait to see it they will help. If not I guess I will go with an adjustable torque arm. It looks like sphoon will be the way to go.Thanks for all the help. Now if it will just stop snowing, and maybe the temp could go above freezing for at least an hour!!!
Tommy
Tommy
That price sounds great! So does the Edelbrock Torque arm have a different set angle than stock, or is it just beefier?
Thanks.
Tommy
Thanks.
Tommy
