Got an empty engine bay here. Need a K member and stuff.
I'm looking for a K member and some control arms. I've also heard that the LS1 brake system is significantly lighter.
Aluminum calipers, lighter spindles? Daily driver, occasional track.
Gimme some ideas fellas. Thanx
Hello,
First, welcome to LS1tech and it looks like you have a nice project there. We will be happy to help with it.
UMI offers a nice K-member and A-Arm kit, light weight, race and street friendly. I posted a few links and I will be glad to answer any questions.
www.umiperformance.com/2320
www.umiperformance.com/230011
Thank you!
Ryan
Thank you!
Ryan
My front end is UMI and I enjoy it. Their K is one of the better with the double front bar. Arms are arms though so look for the best price (which often tends to be UMI anyways).
Then check into Koni shocks and strano springs if you want that lowered look.
A c5 brake conversion will do for the brakes.
UMI makes great stuff. I'm picking up a set of upper/lower control arms when I start the rest of my suspension work, and by the time I need a k-member, hopefully they'll have one with solid motor mount options.
BMR and Spohn also make good stuff, if you want to look at other options.
Hello,
Thank you!
Ryan
Thank you!
Ryan
Originally Posted by UMI Performance
From our research we have found the following wheels will NOT clear with the conversion kit, they may clear with the correct wheel spacers:
2. 93-94 SLP Firehawk wheel- 17” x 9”
LS1Tech Premium Sponsor
This package drops 34 lbs. off the nose:
....and if you want to go crazy, this package drops 84 lbs. off the nose!!
Both kits are very streetable however daily driving, heavy cornering or road course will kill the Strange brakes. If you are building a street/strip car that sees limited street duty they are fine. Would probably suggest the Level 1 kit with OE LS1 brakes. Go HERE to see all of our packages.
Good, its between UMI and BMR for me right now, but I can't decide. UMI's stage 5 is interesting. The stage 6 as well, but I need the "suspension for dummies" book because I do not know crap about suspension and wouldn't know what to do with adjustable upper a-arms!
All I am looking for is a street/strip combo. Need rear suspension as well as far as shocks/spring go...
Don't put to much into the need for "adjustable" on a lot of parts. Most of us weekend racers aren't likely to ever actually need to make the minute adjustments that they allow for, nor are you likely to find a shop that will actually make the adjustments as opposed to using a BFH to merely pound your alignment in place. So the added cost isn't really worth it.
A set of fixed upper and lower arms is really all you need and it just becomes a decision on Poly, roto, or a combination of joints at that point.
As for shocks, Koni yellows (non-adjustable, SA, or DA) on stock is fine or will work with a wide variety of springs. They are just a bit costly.
Springs are gonna depend on what you plan on doing. 275 lbs for drag racing, 300 for a comfortable street, or 325 for a stiff ride.
If you need any help with these kits please ask. Thanks!
Ryan
Hope that helps!
Ryan
