Custom Torque Arm
2) I always dragged my tunnel mount cross brace on speed bumps.
3) I wanted to reduce vibration under my seat for daily driving.
4) Most important was to strengthen the points where the tunnel mount cross member bolted to the car.
5) I did not want to remove my existing welded in subframe connectors.
I made this Torque Arm Cross Member up out of 4130CM.
It uses a Spohn Thrustator rotation joint, and there spherical delrin rod end.
It also uses a poly transmission mount.
Well I will let pictures tell the rest.
I gained 1.375" of ground clearance.
I still haven't lowered it down from the lift but the y-pipe doesn't move andwhen banged doesn't touch the brace. I am worried about the top of the Dog bone brace if hit multiple times will ring the drive shaft. Those transmission mounts allow flex in what if used in the original intended use would be back a forth. It will depend if the force of the rear end is straight up or not as to wether I will have issues.
